Too much oil?
dcompton
Front Royal
I posted this once already and got on reply but that was under a different thread. Then I thought it warranted a new thread to maybe get a bit more feedback....
Ok, so maybe this is a robo rookie question but here goes...
I just finished the aluminum vavle cover conversion. I changed the plugs, the oil and the oil filter while I was at it. According to the Haynes manual, the 258 In-line 6 take 6 quarts of oil. After I put the 6 quarts in and let it sit for a while, I checked the level.
WHY, does it show almost a full quart OVER full? Is there that much crap buried in the engine? I suppose I could drain some out but I don't want to. Damn.
Any ideas?
have you started it yet or turned it over?
The oil filter (new) eats up almost a quart once it starts cycling
try rotating the engine w/ key off (plugs out helps make it easier)
then check it again to see if there is any change.
Yup, what Mike said. Checking the level after a change is pretty much useless unless you know how high over full it usually is before you crank it.
Should be fine once you start her. If it's that full after starting it, you need to drop and clean the pan something awful :D
PS, I suggested hand turning it over slowly as opposed to with the key because if it is a quart or more over you don't want to blow out any seals anywhere..
Not the filter
I did start it after I found it over full with the thought that the filter hadn't been filled yet. I got the same level after it sat for a bit after that.
I just bought this Jeep recently so I really don't know what the "normal" level would be for it.
HOW MUCH
DC 5 quarts is what it should hold,mine holds 5 quarts and the one time i had it changed i had to argue with the guy about how much oil to put in,I finanly won when i told him to go ahead and put six quarts in it and when it was over full he was going to have to drain a quart out,you should have seen his face when he put 5 in, started it then rechecked it,some of the 6 bangers did hold 6 quarts,but mine holds 5 -JC:D
oil
i just posted this on your other thread, too....
i must agree, if it ain't leakin', it's freakin' out of oil completely. i just rebuilt mine, including the aluminum cover and $40 fel pro gasket, and the sucker still leaks a bit (in the 3 months it's been on.) but it's better than the spewing-oil-til-you-have-an-engine-fire type leaks that i had before.
as for the 5 vs. 6 quarts mystery, mine takes 6. a lot of it probably depends on your oil pan, which may vary in size from motor to motor. the oil filter holds a little too. some of the filters are longer than others, which hides some oil. could also be variances in the dipstick itself. if you have a big dent in your oil pan (like i do :p ) that will drop the capacity a bit. there's a million different reasons.
there's also the possibility that the oil is leaking out so fast that it appears you need more than you would otherwise :rolleyes: ...
good luck. always carry a quart with you. that's my rule!
BEN
fill the filter first
Learned this one from my college roommate, who has CJ7. When you change the oil, pour some oil directly into the filter before you screw it in. Don't have to fill it all the way up, 2/3s is good. Then oil the gasket and screw it in. It's easy to do since the filter sits somewhat upright on the engine. Just don't tip it too far trying to get it into position!
I have friends who purposely put an extra quart of oil in the engine to assist the pickup on steep inclines. It will take an unimaginable long time to damage the engine with a little extra oil, but only a few seconds without oil to ruin the eninge. I know for a fact due to my stupidity, the 4.0 I6 will run with 12qts in it, no leaking or blowing of seals.
P.S.
Been lurking for a little while because have been doing research on possibly buying an 84. If I get it in the next day or two will be on this board a lot more with a lot of questions.
