Is your CJ tub a "Jeep" or a "Joop"
CJ-8_Jim
NW Chicago Suburb
IL
I'm trying to determine whether my tub is original to my 1985 CJ-8.
The die-stamped imprint behind each front wheel well says: "Joop" (the decal applied over it says "Jeep")
Is this correct for a 1985 CJ?
I know some CJs were stamped "Jeep" but I don't know what years nor if those years included CJ-8s.
Thanks!
Jim
my 85 is JOOP too & it's original (bought it that way in 85 ;) )
Never noticed that before. The '85 7 is a Joop, the '84(?) 8 is a Jeep. I always suspected the Scrambler body was not original to the frame. The body has some metal replacement and bondo. The frame looks like new. I didn't ask a lot of questions about the Scrambler when I bought it. You all know how it is when you want one badly and then find one that looks good (I did check it out good though - saw what it had and saw what it needed. Knew about the new metal but didn't spot the bondo for several months. Paint can hide a lot).
Mine's an '84. I think it's halfway between Jeep and Joop, the 'tails' of my e's (for lack of better description) are not closed up to make o's, but the center of the e's are solid.
YEP
83-Joop
84-Joop
both of mine are-JC
Mines and '83 and is a JEEP
Them open "E"s make it hard to put them purty letters on though.
tomthbomb said:
The stamping dies wore out close to the end of the CJ run.
tom
Sorry to "quote" myself, but......
The stamping dies that said "Jeep" wore out and stamped out a bunch of" Joop's".
It happened gradually so you may have a "Jeop" on one side and maybe a "Joep" on the other, or both, or neither.
tom:rolleyes:
p.s.
it really p's me to see it spelled "JEEP" (Aggies excused, of course, Gig'em!).
I've been doing a little research today on this site, so here's a blast from the past (i.e. resurrecting an old post). Yesterday, I went and looked at an '81 "Joop" Scrambler. It didn't jump right out at me, but my GF mentioned the stamping on the way home. We were riding in my '81, so I looked down to confirm the "Jeep" stamping on my tub. Then, I also confirmed the "Jeep" stamping on my '83, when I got home.
Without knowing the reason for this "Jeep" vs "Joop" difference, I assumed that the tub wasn't original to the '81. Then, I wondered why someone would replace a CJ8 tub with one that was so rusted out. So, inevitably I concluded that it was probably the original tub, but that my Laredo models must have received a little more attention than the Renegade models, such as the one I viewed yesterday.
Anyway, this morning I decided to search this forum for the answer. If the answer noted above is correct, it would appear that the "Joop" is not specific to any year, and AMC must have gone through a lot of "Jeep" dies each year. Personally, I'll continue to conclude that Laredo model CJ's simply received more attention on the factory floor.
Does anyone have a Laredo model "Joop" CJ that can disprove my theory?
