Rear Seat in an 8
Wayne
Cape Coral
FL
Hello:
I am going to put a rear seat in my 8.
The seat sounds like a no brainer - just bolt one in between the wheel arches.
My main concern is the seat belts.
I have two small kids and I would like them to each have their own seat belt.
I have looked for rear seat belts but I can only find a non retractable 60"belt.
If anyone has any advice I would appreciate it. ( would the 60” belt be safe enough )?
Also if anyone has photos of the rear seat and belt that they could share that would be great.
Thanks,
Wayne.
I used the non-retractable ones in the rear when I added my seats. Those things have to meet safety specs to be sold to the public I figure.
The thing about the retractable ones is that the anchors are on the bed floor, so if you're using a fold-n-tumble and need the bed, you'd have the retractor sitting there in the middle of the floor where the non-retractable ones just lay pretty much flat.
Short of having a cage built with anchors for shoulder belts, I don't see how you'd do much else.
Cheers,
I was thinking about the belt anchors myself.
I have a stainless steel diamond plated box that I will have to shave an inch of and relocate it aft of the seat and the belt anchors will not allow me to put it there.
I guess my main concern is that the belt strap does not retract and I do not want the belt to be so lose that my kids slide up and down the seat. Then again going around the kids bodies may take up the slack??
P.S.
Sweet Postal you have.
I have the retractable ones mounted on the fender and the buckle side is bolted down where the seat is bolted in the rear. I can take a picture if you want.
I'd like to see pictures for sure. Where'd you get the belts?
It will be a long while before I need to actually belt a kid, it'll be a carseat that's being used for a few more years. So the non-retract wasn't as big a deal for me. I can see the worry though with no carseat...
When I did the full cage, I had them weld in upper and lower mounting bosses for LJ belts, so that's my ultimate setup to get three-points in there.
I can't say as I've seen a retractable lap belt setup in the rear, pics would be appreciated :thumbsup:
Thanks, if it not to much trouble I would like to see a photo.
Thanks again.
Wayne.
When mounting a seat in the rear of a Scrambler, a neat idea is to build a lock box under it, so the seat is raised a bit. This is a luxury for leg position when anyone other than small kids ride in the back. It also offers a hidden type of storage for a number of items.
Wayne - The non-retacting belts are still adjustable at the buckle. They won't be loose on your kids.
Here are the photos of the retractable belts I have. The previous owner had them and I do not know he got them.
I didn't take a picture from under the fender were they are bolted but I have about a 2 1/2" washer there for support.
I too just used lap belts. They were actually ones I had from a previous CJ7 I had. I used some thick bracing (3/8") underneath to bolt it down to.
Thanks, I just got some yesterday they will work perfect.
Hope to have the seat and belts in very soon.
Wayne.
Hello:
You guys helped me out the other day regarding installing a rear seat in the bed of my 8.
I just bought one and installed it so I wanted to share some photos.
I got a BestTop Trailmax 11 fold and tumble with the head rest.
I had some holes in the bed that had backing nuts on them so I think that they were original holes for the seat when the jeep was new?
I did not use the holes that are there, I drilled a fresh set. I needed the seat to be more forward. I have a diamond plate box that will be bolted down behind the seat right up against the tailgate.
I can see what you mean by no leg room for adults. I took the bulkhead out and I may leave it out for awhile.
My kids will be using the seat the most and leg room is not a concern right now.
When I drilled the holes I went back 14” back from the front of the sheet metal ( truck bed ) where the bulkhead would sit.
It kind of worked out better that way because I had to drill another set of holes for the lever at the back of the seat that holds the seat down and in place, when I drilled the holes I was just forward of the fuel tank. If I had used the original holes I would have had to remove the fuel tank to get to the nuts to tighten the nuts down.
I used two 60” rear seat belts. I did use the original holes to anchor down the strap part of the belt. I may have been able to get away with one belt but I think two separate belts might be safer.
Overall I am pleased with the seat, the kids love going out in the Jeep. With the wife’s help it took me about 1 ½ hours to install.
Thanks for every ones input.
Wayne.
Just to be a stick in the mud, you are not supposed to attach two different belts to one mounting point. (Please don't look in my cab).;)
I used the non-retracting ones in Sam's, but I like the looks of the retracting ones. Do you have a top on there all the time? Weather + retractable = not good.
I keep my full soft top on most of the time. As of last week, my 8 is no longer my daily driver so it will not be seeing the bad weather like it has since June.
