For a CJ-8, a Ford Contour dual fan is a better choice - it's a perfect fit for the radiator, and it is thnner than the Taurus fan, so there's no problem fitting it between the water pump pulley and the radiator..
Here's what mine looked like when I installed in in my Scrambler radiator...
That looks like a perfect fit. I like the ideal of backup in case of failure. How did you wire it in?
I used a DC Control electronic variable speed controller with a radiator probe temp sensor.
The DC Control unit is a great piece of technology, but they are somewhat challenged when it comes to customer service, so if I were doing it again today, I'd use a Flex-A-Lite controller, they have an electronic variable speed one with the same features as the DC Control unit.
I also built a small fan control box that I mounted on my dash - the top LED glows green when the fan isn't running, and as the controller starts spinning the fan, the LED goes from green to yellow to red depending on how fast the fan is spinning. The fan speed is a function of the electronic controller, the more cooling needed, the faster the fan goes. The switch provides manual control of the fan, it has three positions - always on, normal (automatically controlled by the electronic controller), and always off.
Thanks, I knew when I asked that you went that extra step....... The override switch comes with the Flex-A-Lite controller, but knowing the speed would be a nice feature. I found their light on the DC Control website.
Jscherb....where did you find that great little check engine light??
NICE
This dual fan is from a a mid-nineties Ford Contour SVT with the higher performance engine option – either the 16 valve “Zetec” engine or the 24 valve 2.5l “Duratec” V-6. The dual fans pull 3400 CFM in total and also provide redundancy in the event of the failure of a one of the fans. The Contour fan is also more than an inch thinner than the Taurus fan at the motors, and it is a little less then 3 inches thick between the motors where it would meet the water pump pulley, so it fits perfectly no trimming of the shroud necessary.
Is it ground and 0-12VDC only?
