Fuse
What I mean by Speedo post, it is a push on connection:
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Oil post is also a push on connection by default.
attachment.php
Disconnect the three wires per above to check if you have a short in your wire harness. The bare red wires should not bump up against your dash. That would be a short. The wires should have insulation on them preventing them from shorting with the dash. If you can see where the bare wire is touching the dash, that is probably a problem. The cig lighter should be on a different circuit with a larger fuse.
I have know idea why the three photos I took are not uploading?
I guess the red wire with the 90 degree end is a spare as I do not have a cig lighter.
I will take the laptop out to the garage later and try and duplicate what you have.
I cannot keep saying thanks, enough times.
Be in touch,
Wayne.
Hey Fellas:
I have been through the process of elimination.
Before I go any further – what does not make sense is the RED wire going to the post on the back of the cluster – it is not RED.
The post is at the back of the fuel gauge??
I have attached two photos. I am confident that we are all on the same page when it comes to the post on the cluster.
One photo is from the back of another cluster that I have, I have heighted the post where a red wire would go.
The other photo is just a better photo of the back of the cluster that is in the jeep now and the post and the wire is highlighted.
I removed the two wires and the 4WD bulb I screwed the cluster back to the dash and I then screwed the dash back to the jeep in a couple of places.
I put a fresh 3 AMP fuse in and put everything back one by one.
1. I put the bulb back cranked the motor – turned off and the fuse was good
2. I put the oil red wire back cranked the motor – turned off and the fuse was good
3. Put the WIRE back on the cluster cranked the power – turned off and the 3 AMP fuse was blown
So thanks to you guys I guess I know where the problem is? Would you have any idea what is causing this pain in the bum.
I cannot tell you why the wire is not red.
Wayne.
Congratulations! You have narrowed it down to the Speedo cluster. The next move is to unplug the two wires that leave/exit the cluster (they go to your fuel sensor and your temperature sensor). In your actual photo you have them labeled 3 and it looks like 1. Pull those wires off and leave them hanging, plug your red(orange?) wire back onto the speedo post, replace your fuse, and start the car. If the fuse blows right away, the short is in the cluster. If it does not blow right away then plug in the temp sensor and see if it blows, if not then plug in the fuel sensor. You will thus isolate the short further.
Does that red(orange) wire go straight back into the wire harness or does it run up into some sort of splice?
I have developed a small minor problem
I have/had blue tape on the wires because I took the cluster out 6 months ago and I wanted everything to go back in its correct place.
Well the blue tape came of today and I have put the wires back in the wrong places.
Would you know what is the correct sequence?
When I put the 3 AMP fuse in its slot slowly all the dash lights come on and the 3 AMP fuse blows also the 25AMP bu seatbet fuse has blown.
Running out of 3AMP fuses.
Wayne.
That redish / orange wire goes back into the harness
Sorry.. As you look down at the photos the oil is on the left and the volt on the right
You took the wires off yesterday?
Is this a new problem or just an observation of the old problem?
In the photo of the oil and volt meters there is a red wire that turns into a black wire. Is that going to your radio?
Do you know how to use your new meter to measures ohms?
No the wires came of today and the blue tape fell of today.
This is now a new problem.
The wire that looks like it goes from pink to black is just an illusion. The pink wire is what I took out when I was going to do the second test that you had mentioned and the black wire is just lying on the floor underneath it.
I have no idea what the black wire does?
The volt and oil gauge look fine. Do you think you might have been blowing that 25 Amp before and you just didn't notice or are you sure this is new?
If we go back to square one with the three red wires diconnected are you still blowing the fuse?
They make more 3 Amp fuses, but if you can figure that meter out, we might be able to save you a couple.
So we agree, great!
I don't think you posted a picture of the speedo gauge since yesterday, so are those wires still the same as yesterday?
Does the 25 and 3 amp fuses only blow when the red/orange wire is connected to the speedo post?
Put another way, how are you set up when the 3 amp and 25 amp fuse blow. Is it with all the wires connected? Is it when you have the red/orange wire disconnected? What were you doing when the 3 amp fuse blew?
You had isolated it down to the following:
Fuse is ok when 4wd light is plugged in and oil and speedo are discconected.
Fuse is ok when 4wd light is plugged in and oil is plugged in and speedo is disconnected.
Fuse blows when 4wd light is plugged in and oil is plugged in and speedo is plugged in.
Is all this still true? Don't give up we are almost there.
No I do not think I sent a photos of the cluster today.
I was concerned about the wires that came loose on the oil & volt gauge, I am sure I have them back in the right positions?? hopefully.
This is what is happening now - the 25 AMP has not blown since it blew the first time.
When the red wire is in on the speedo post and I crank the motor the 5AMP fuse blows, when I take the red wire of the post and crank the motor its fine - yes 5AMPonly got one 3AMP left gone though a bunch today, will a 5AMP work for now??
5 Amp will work, I think the owners manual actually calls for a 5 Amp even though 3 is printed on the panel.
The red/orange wire is the "goes into" wire that brings power into the speedo cluster for the fuel gauge and the temperature gauge, that's all it does, nothing else.
You have a pink colored wire plugged into your number 3 which is your "goes outa" wire where the current leaves to feed the temperature sensor under the hood. It is fed current by the red/orange wire.
You also have a pinkish colored wire plugged into you number 1 which is the "goes outa" wire where the current leaves to feed your fuel sensor in your tank. It is also fed current by the red/orange wire.
These are the only two points that the current should leave out of you speedo gauge in reference to this particular circuit problem. It comes in once and leaves twice.
Your short and blowing of the fuse means that the current is returning to ground before it reaches the fuel sensor or the temp sensor. This short can only be in one of three places.
1) In the speedo cluster itself.
2) After the speedo cluster on it's way to the temperature sensor.
3) After the speedo cluster on it's way to the fuel sensor.
That's it, one of those three places, and we can test for that with the meter or with the fuses.
To test with the fuses, unplug both pink wires from your number 3 and number 1, and only those two wires. This will stop the current from flowing to your temp sensor and your fuel sensor. Plug the red/orange wire back into your speedo post.
If the fuse blows you know that the short is in the speedo cluster because you have disconnected the other two options.
If it doesn't blow, plug in the temperature sensor, if it now blows the problem is the temp sensor leg.
If you still haven't blown the fuse, then the problem is in he fuel sensor leg. You could plug the fuel sensor back in to watch the fuse blow to prove it.
Ok I took the pink wire out and the other pinkish/purplish looking wire out and left the middle wire in crnked the motor and the fuse did blow
Hello:
Yes I still have the new one. I was going to throw on on Craigs List but I should probably try to swap it out with the old one? I put it in before for about an twenty minutes and the gauges still did not work.
So I stuck the old one back in.
