- Reston
- VA
What I mean by Speedo post, it is a push on connection:
Oil post is also a push on connection by default.
Disconnect the three wires per above to check if you have a short in your wire harness. The bare red wires should not bump up against your dash. That would be a short. The wires should have insulation on them preventing them from shorting with the dash. If you can see where the bare wire is touching the dash, that is probably a problem. The cig lighter should be on a different circuit with a larger fuse.
