Fuse
Hello:
Yes I still have the new one. I was going to throw on on Craigs List but I should probably try to swap it out with the old one? I put it in before for about an twenty minutes and the gauges still did not work.
So I stuck the old one back in.
Did you check the 3 amp fuse first before you put in the new gauge?...... The fuel gauge has the cvr (constant voltage regulator) built into it and then it feeds the temperature gauge. That is why there is only one power feed. It seems lilke this may be your problem, which the fix is replacement of the fuel gauge or in your case since you have the new speedo replace it. A test for the sending unit is to ground out the connector at the tank on the frame and watch the needle move to full. You just don't leave it there long of you could damage the gauge. This is how I proved my problem was my sending unit. That is the same procedure for the temperature I believe. Keeping that in mind if you hook up the new and the gauges go to full when you are not or to hot, I would turn off and look into that.
Wayne,
You have a short in the speedo gauge. On the back of your gauge you have a a piece of metal strapping that goes under a nut on the fuel side, runs over to the temp side and also goes under a nut. In your photo it looks like it has blue tape on it. Is that metal strap touching the metal chassis of the speedo gauge or touching the speedo post?
I cannot remember if I checked the fuse when I put the new cluster in?
I am going to get the new cluster and put it in first thing AM - check the fuse and keep my fingers crossed.
apologize - but I am lost when you mention testing for the sending unit – do you mean the sending unit in the fuel tank? Also I do not know what you mean about grounding out a connector - sorry.
I was thinking about dropping the fuel tank and replacing the sending unit.
I found a wire that comes of the tank and connects to another wire that runs up the left side of the frame, I checked the connection but it was good and clean.
So can a cluster/Speedo go bad, even if the all the lights work?
Wayne.
I took the black rubber of because it was falling apart and put the blue tape on because - I have know idea, just did it.
The strap just goes to the the two threaded post at each end, it does not touch the cluster. There is some kind of paper under the strap it does not touch the post where the red wire goes.
I took the strap of and checked the ends to see if the were dirty but they are clean.
Wayne.
RustyCrawler is correct that you would check that strap and the speedo for any physical damage first and if everything looks good the next checks are cvr in the fuel gauge as it can short to ground. Since you have the parts and have had it in and out it may be easier for you to swap out.
That is the correct connector you are referring to. I just used alligator clip to ground and the needle moved to full. If that happens that means all the wiring from your speedo to your tank is good and the problem has to be the connections at the tank or the sending unit itself. The sending unit is inside the tank and is a float, pick tube with filter or sock and variable resister. This is what the one wire and a ground connect to on top of the tank. Mine was a corroded float, so since I had already purchased the sending unit I just replaced it. From reading I am guessing that everything worked and then one day it did not and was not the result of any disassembly or rebuild. If you lost both gauges at once this seems like the most likely scenario.
That blue tape seems great for painting trim and for labeling wires in a pinch, but it is a horrible insulator for electric current. You could try taking the two nuts off and removing the strap entirely.
With the strap removed, both purplish wires disconnected, and the red/orange wire connected, if the fuse still blows it is the CVR, if it doesn't blow, it's the strap.
I agree that would be a good thing to do. If your fuel gauge was not working and the temperature gauge was and in your troubleshooting you took the apart the gauge this could have caused the short you have now. If that is the cause I would take care of the short and look at the sending unit. The big advantage with the original speedo would be the mileage would still be accurate. You can always replace the gauges if it is the cvr in the fuel gauge and sell the new one or roll the new one to the current mileage, but this requires disassembly.
Doing it, I got to get my DD back together today.
I will be in touch,
Cheers.
OK gentleman:
I took the strap of and put a few layers of electrical tape around it, it’s all I have that will go around the bend in the strap.
I removed the pink and purplish wires and left the red on the post put the cluster back on the dash and attached the dash to the jeep.
Turn on the ignition and the fuse blew.
I then put the strap back put the wires back put in a fresh fuse ( boy I need to learn how to use that meter ) and the fuse blew – I guess no surprise!
So then I took the wire coming from the fuel tank ( photo attached ) a long piece of wire (photo attached) attached one end of the wire to the wire coming of the tank ran the other end up to the back of the dash – cross my figures, turned on the ignition and the fuse blew.
So I decided to put the new cluster in and basically nothing happens to the gauges. The temp gauge moved and pegged but it returned to cold and the fuse - keeps a blowin.
As always thanks very much.
Wayne.
Post a picture of the front of your meter. Probably has a big twist knob on the front of it.
I'm starting to question that red/orange wire. It seems that whenever you plug it in, the fuse blows. Try this if you can.
Unplug the red/orange wire feeding the speedo and let it hang. Unplug the purple and pink "goes outa" wires from the speedo and let them hang.
Unplug the red wire from the back of the oil gauge and plug it into the speedo post if it will reach. See if you are still blowing the fuse.
Multimeter.
I put one point on the strap and the other point on the post where the red wire goes and the needle went all the way up.
I did the same on the old cluster that I just took out and the needle went all the way up.
Thank you.
Cool, nice meter. We are going to use only two of all those settings for all these test. The first setting is exactly where you have it in the picture, the "OHM x 1K" setting. The other setting is three clicks to the right of that one, the "50" in the DC V group.
The ohm setting measures if there is a path for the electrons to flow and if so, how hard is it for them to get around. The very top line in your meter display has a zero on the right and a 1K on the left. If you set the meter to the ohm selection as in your photo and just hold the meter in your hand and touch the red meter wire to the black meter wire, you will see it jump to zero on the far right. If you untouch the two wires from each other it jumps to 1K. (short for 1,000)
Zero is a path for the current to flow, 1K is a no go.
The other setting, "50" will measure volts. Your car is a 12 volt system, so you read that in the middle of the dial where it says 0 10 20 30 40 50, but you have to turn the dial to 50 first, the meter will read 0 for no volts, or fall between 10 & 20 for 12 volts.
Unplug the three AMP and fuse, red/orange speedo wire, and red oil post wire. Take a ohm reading between the red/orange speedo wire (not post) and the red oil post wire (not post). It should read about zero. This will tell us if the red/orange wire is OK.
Thanks.
I did that and the fuse blew.
Doing it now.
The 3 AMP fuse is out the red speedo wire of and red oil wire of.
I am putting one wire end from the meter in the end of each red wire ( seperatly) I cannot remember where the other point of the meter wire goes - on the body of the jeep??
So with one wire of the meter on the red/orange wire of the speedo and the other end of the meter on the red oil wire, the reading is zero ohms. That means it is the same wire, as it should be, maybe they just ran out of red at the factory that day and used a little orange.
You can put that wire back on the oil gauge and put in a new fuse.
Leave the red/orange wire off the speedo post so you can drive around without blowing the fuse, you should have your 4wd light and oil pressure unless something else is broken with them.
With the speedo post wire off and the purple and pink "goes outa" wires off the speedo, take a ohm reading between the speedo post and the metal frame of the speedo gauge, anywhere on the back. It should be 1K, but it sounds like it is going to be zero, which is why you are blowing the fuses. Check it an see what it says.
Went from the post where the red wire would go to the outside of the cluster and it was zero.
