4miles
- Virginia Beach
- VA
Hello:
Yes I still have the new one. I was going to throw on on Craigs List but I should probably try to swap it out with the old one? I put it in before for about an twenty minutes and the gauges still did not work.
So I stuck the old one back in.
Did you check the 3 amp fuse first before you put in the new gauge?...... The fuel gauge has the cvr (constant voltage regulator) built into it and then it feeds the temperature gauge. That is why there is only one power feed. It seems lilke this may be your problem, which the fix is replacement of the fuel gauge or in your case since you have the new speedo replace it. A test for the sending unit is to ground out the connector at the tank on the frame and watch the needle move to full. You just don't leave it there long of you could damage the gauge. This is how I proved my problem was my sending unit. That is the same procedure for the temperature I believe. Keeping that in mind if you hook up the new and the gauges go to full when you are not or to hot, I would turn off and look into that.
