Hydraulic clutch install
Gracias!!
just a bit of info....looks like the parts store lied. they told me the master and slave were 7/8 in bore. looks like the master is actually 13/16, and the slave is 7/8. but i still dont have enough throw??***??!!
the only available master for any year CJ is 13/16. and the only available slave is 7/8. there is definatly not a 1:1 ratio there...seems to be under driven..I guess I need to find a 7/8 master or a 13/16 slave.??????
Found this on Novaks site , don't know if it will help or if you've already seen it.
http://www.novak-adapt.com/knowledge/clutches_etc.htm
been there several times in the last week....searching to see if i missed something....shot them an email telling my woes. Hope to hear back soon!!!
do you remember your buddies set up? is it the same? 13/16ths master, 7/8ths slave? maybe all my local parts stores are just morons:angry::banghead::(:mad:
so the combination of 13/16ths slave and 7/8ths master will not release a 10.5 inch clutch, it was designed for a 9inch clutch....UNLESS...you change out the fork to some unknown or increase the size of the master, or decrease the size of the slave.
NOW WHAT!! I just spoke to Novak...they didnt like the idea of the 3/4 slave with a 13/16ths master...they thought it would blow out.
Some of the problem I'm dealing with is the jeep was origanally equipped with a four cylinder with a factory hydralic clutch. It had previously been switched to a small block chevy with a sm465 trans , I built a new engine for it and istalled a new clutch. After I installed the new engine I went to put the old one on my stand and upon removing the clutch I found out the old one was an 11in and I put a 12in in it's place. Before I swapped in the new clutch it was fine. I just looked up the parts on summit and it shows the slave to be 7/8 and the master to be 13/16 (1980 cj7 with 151).
I found a 7/8ths master at Jegs. Just a bit spendy, over 100 bucks...still gonna keep searching. Tilton makes it...gotta be cheaper somewhere!!!
Novak is still scratching their heads...told me to give them a day to research.
I don't know why Novak thinks a bigger bore master would blow otu the slave , I've done the same with brakes and I have never blown out a wheel cylinder. If I remember right a smaller bore master increases the pressure and a larger bore just increases volume. As long as the slave has a snap ring in it to retain the piston it shouldn't blow out .
Just came in from working on the jeep. I don't have anywhere near the mechanic experience that you do, so I have been relying on research and recommendations, and am lucky to have a few friends helping me out.
I swapped in an LT1 with sm465. Went with the Centerforce Dual Friction Clutch...which is a 12" diameter friction disc. After reading what you said about the different size clutches making a difference on how the Hydraulic clutch will work, I'm getting a little nervous!:eek: Everything looks like it is working now but the jeep is not running so I am not sure.
Jeepthrills - I tried to measure the throw at the pic connector at the pedal and came up with about 1.5" of movement in the push rod. The slave cylinder arm moves just over 1", but those measurements aren't exact becuase I was taking the measurements by myself, which was hard to do.
Anyway, hopefully the jeep will be running within one month and I will know for sure if the clutch is working. Please keep me updated on your situations.
thanks!
-Mike
Thanks for helping with the research...but factory slave is 7/8. Thats what I have...Need to consider a 13/16ths slave.
Apparently 4WD and Quad have different part numbers for 4 and 6 cyl slaves...They are calling their respective suppliers on monday to verify diameters. Fingers crossed!!
Just had a thought....maybe I could back fill the slave with JB Weld to make the volume inside smaller...which should equal more push!?!?
Sorry read back a little , for some reason I had it in my head you were looking for a 7/8 slave:banghead: . Putting jb weld in it will shorten your stroke . I was doing some searching on clutch forks and I noticed that they offer a different one for the G.M. four cylinder , but like most web sites they used a generic picture and I could'nt tell the four from the six.
After rereading the thread , your origanal problem was not enough adjustment but the pedal felt good . I think the problem is stroke wich goes back to the throw out bearing , fork or a slave that doesn't have enough travel .
the problem is that I have to use a non stock spacer to get release of the clutch...but the spacer causes the T/O bearing to be buried into the PP fingers with no free play, and I cannot adjust it (with different spacers) to get freeplay, and full release.
The spacer is making up for the lack of travel wich means that the bearing is starting out to far away, bearing is to short or the fork has the wrong geometry . I know you didn't want to hear this ( from our earlier post ) but I think the trans has to come out and the bearing or fork need to be changed , I know it sucks but I believe that is the answer. The only other thing I could come up with is modifying the fork but I don't like that idea.
I had napa order in a replacment to take some measurments. Also went over to CSK and took measurments off the Valejo clutch.
All measurments were basicly identical, and compare exactly to what I installed. Also Napa verified with the manufacturer that this clutch was intended for use with hydraulic and conventional linkage.
One of the outside sales reps (my old rep from when I managed the shop here in town) did not have good things to say about their "precision" brand clutches. Says they usually have problems with linkage alignment.
I had them order a B&B style clutch into the store so we can do some comparisons.
Light bulb!!!!!!!
ok...humor me here.
all 6 cylinder t-5's comes with a 10 spline, 1 1/8 input... correct?
all 4 banger t-5's are all 14 spline...correct? WRONG!!
Early t-5's with GM 151's were 10 spline 1 1/8th same as the 6 cyl except 9 1/8th diameter clutch instead of 10 3/8ths (it wasn't till the intro of the AMC 150 that they came with 14 spline). All the bellhousings are the same (I think:confused:).
Catalog check...GM 4 banger clutch fork is different that any AMC.
The tranny I got, may have come from an early 4 banger...I used the fork that came with it because it was in good shape, and I thought all 4 cylinder trannys were 14 spline, and this was 10. So unbeknownst to me...I used a GM 151 fork instead of an AMC fork. I am sure they have a different ratio.
What do Y'all think?
AHHH crap!!
if it was an early 151 tranny...it would have a GM bellhousing.
Back to the drawing board.
stupid clutches...
Sigh! I'm just reading along and I have felt your pain! Offering you my simple support and some encouragement! Good luck!:)
OK...Better light bulb!!
Had the parts store order in a 3 finger B&B clutch. We sat it down next to the Diaphram unit, and took a bunch of measurments.
Seems that the B&B is actually .325 inch taller than the diaphram. According to travel/throw measurments, my slave is moving a solid inch, and the T/O bearing is moving about a half inch.
So with a pressure plate that sits .325 farther back, that means i get roughly .6 inch back on the slave side of the fork. Which should allow me to remove that stupid spacer, and with the same half inch movement of the T/O bearing, I should have full release.
So in theory, using a B&B style (heavy duty) clutch, should allow the use of hydraulic linkage.
I am going to try to prove this theory on Saturday...Keep Your Fingers Crossed!!!!!
Comments are always welcome. Please someone find a hole in this theory before I yank the tranny...again.
Finally installed the 3 finger yesterday. Big difference. I still need a spacer...But with a little allthread and a couple nuts/washers....it should be serviceable!!
So for all of you going with hydraulic...make sure you use a 3 finger clutch!!
