Question about Tire Cost
TXtrailbuggy
It sure is smokey in here
Kyle
TX
Why is it that the cost of a tire increases dramatically when you increase the wheel diameter even though the tire's diameter stays the same?
example:
35x12.50x15 BFG KM2 - $200
35x12.50x17 BFG KM2 - $330
I figure that there was less rubber so the cost should less.
Anyone know?
Thanks, Bo
Tooling and material cost for the 17" most likely.
they have been making that 15" tires for what 30 years or more, with only minor changes for the most part (tread pattern and carcass materials).
The 17's are relativly new to the market and require a very different carcass (which means new tooling) and probably different carcas materials in some shape or form.
Really, the 17" only uses a little less rubber, and thats a very minor cost compaired the the cost of the carcass and new tooling to produce it.
Hope that helps
It won't be too many more years and it will flip-flop. There are very few vehicles nowadays that come from the factory with 15" wheels/tires. Most commonare 16" & 17", if you don't believe it go to a wrecking yard and ask for a used 15" tire! LOL!!!
Hope that helps
See what your saying but its the same fo 16's also, seems the less the rubber the more the tire. CRAZY:crazy:
