Picked up a V8 or two...
Going Postal
Corvallis
OR
Got myself a short block 304 and a set of heads. Not sure exactly what I have but casting number on the block is 3185527 and has 304 stamped in teh side. Heads have had some work done. there 360 heads, 3231475-2, there is a sheet of paper in the port that says 1971 304 heads, custom flow job by Hutch in Stayton, SBC Valves, Edelbrock Springs / Keepers New Bronze guides. They have dual springs on them and are set up for screw in rocker studs. Chambers have been pollished as well as exhaust ports. Looks like these heads were run on this 304 but I don't see any clearencing for the larger valves in the block???
I have no idea what cam the block has in it or if it's been bored or really has a 304 crank and rods. But the pistons have a dish to them and four valve reliefs each.
The other engine is a 75 360 with about 70K on the clock. It's complete pan to pan with all accesories on the front end. Looks like it was just pulled.
Not sure which way I'm going with this stuff but I think I have my V8.
Got all this for $475
Need some help figuring out what I have here...
Head casting 3231475-2 with intake valves 1.87 and exhaust at 1.59. Are these some type of SBC valves? Casting numbers show these heads as 360 heads and should have had bigger valves originaly. The slip on paper I found stuffed into the intake port said 71 304 head and they are set up for screw in studs. Ports have been pollished and chamber smoothed out alot. I'm thinking I'll build the 304 block and run these on it. It looks like it's standard bore with 304 stroke measured with a 6" caliper from the deck.
I also have two factory 4bll intakes. casting # 3224347 and 3217486. One has two of the four holes closer together and the other has them evenly spaced. Is this a spread bore type intake? Why are they different?
re: intakes, AMC used two different 4 barrels. One was a Motorcraft or Autolite 4350 which was a spreadbore design-- big and little holes like a Quadrajet.
Does one flow better then the other? I still need a carb so my options are open.
