Low Oil Pressure (HELP)
Remington19
Stevensville
Looking at an 81 CJ-8 however the oil pressure starts off at 25 and goes down from there. The guy that has it for sale said it just needs a new oil pump.
Should I avoid this purchase or is he right about the new oil pump being needed ? :shrug:
I am new here and looking to purchase a Scrambler just not sure what I should stay away from. Advise needed from all of you.
Thanks
Down to what? Zero? Is this with it just idling after it starts? Have you driven it/revved it to watch what it does?
Oil pressure is notoriously low on 258s, it's like they wasted money on the upper half of the oil pressure guage (unless you've swapped engines). It's been a while since I swapped in the 4.0, but I don't think I ever saw any oil pressure over 25 on my 258. It was only that high at startup and when you got on the gas.
So in the end, my take is that as long as it's noticably positive at idle and goes up when you goose it, you're fine and may not even need the oil pump, though it's not a bad thing to replace so you know you're set.
Research it and compare to what you've seen.
I don't think there is enough information here to make an informed decision. For example, and only for example, let's say the entire engine is bad. It may be a great purchase, if the body is good, frame is good, and the price is right, it might still be a fantastic deal.
It might also be that if the engine is bad, the seller is asking way too much money, rust holes in the floor, transmission shot, needs brakes, and smells bad, that it is a horrible deal.
Are you really curious if this is a good deal or are you just looking for information as to why oil pressure might be lower after start-up?
(Edit BigWalton and I posted at the same time)
Good points, we can help on the purchase as a whole if you like, just need details and photos. I was addressing the one question about oil pressure assuming you were ready to judge the rest. Generally, people are very good here about respecting another guy's deal, but if you want me to help post info without giving away the location/seller, I'm happy to help, just PM or email me.
When she's cold, mine will read up to 40. While running warm, she's steady at 20, dropping slightly below that when idling at a stoplight, etc. As the three months between oil changes went on, she'd read lower and lower when cold. Sounds like if you purchase, first thing on the agenda is an oil change!
I've read something like 10psi/1000rpm on the internets.
What's the mileage on the engine? Is the engine covered with oil? Does it smoke?
I have a very high mileage vehicle that starts at 55 psi and drops to about 25 after it warms up. 4th gear at 35 mph is about 20 - 25 psi. 5th gear at 75 mph is about 35 - 40 psi. It always goes up after an oil change. At idle it's maybe 10 psi. 325000 miles :thumbsup: I can't complain.
I own an 81 with a brandnew 258 from gunner engines out of TN. I'm steady at 20-25 psi and it goes a little lower at idle. Mine too goes lower and lower as it comes time for an oil change. Like bigwalton said, they are notorious
Wow, that's impressive. I never came close to seeing 40 on mine, that much I'm sure of.
mindscrambled sounds about like what I remember.
Robert, is that a 258 or your 4.0?
I run 10W40 high mileage for what it's worth. Thicker oil will give you higher pressure readings. (and fewer leaks!)
And part of me thinks the oil gauge may be more of a "relative" reading. If you know your pump is good, you've got 5qts of oil, and no severe leaks, any reading is relative and you might only get aroused when the gauge bottoms out.
That's the Trooper. I've been worried about it a little but it still runs strong. The 4.0 in the Scrambler stays close to 50 - 55. It has about 90,000 miles. I don't see much fluctuation as I drive, but then it's hard to see my oil pressure gauge. It's an aftermarket 3 cluster gauge mounted below the radio.
When I bought my Scrambler, the oil pressure gauge did not work. The PO had wired it wrong and I got no reading at all. Once I rewired it, the reading was only about 10 and would drop to zero at idle. Scared me to death. Checked it with a mechanical gauge and it holds a steady 25. Still concerned but it runs great and no knocks.
Wow, just wanted to know if the low oil pressure being low 25 to zero was normal for Scramblers and I wasn't buying something with a total junk motor. Cant afford to rebuild it should I buy it.
Thanks
PM sent
One other thing to consider...the stock gauges are notoriously wrong. Mine was reading near zero all the time. I decided to put in a mechanical gauge to check it out...and was reading 20 at idle and 40 while cruising down the road. Stupid stock gauges.
Also, if pressure really is an issue. From my recollection, a high output oil pump from a 4.0L is supposed to bolt in with only a slight modification (from a hammer) to the oil pan.
My 258 has always had very poor pressure at idle. 50+ when cold, then drops so low it barely moves the needle. Picks up to 25-40 just above idle though even when hot. Been running like that for years. I believe the factory spec at idle is only 14 psi.
My guage looks the same and will bounce around. Will changing the guage fix this?
