anyone use a cordless impact wrench?
Bushmaster6
the Springs
CO
Amazon has what appears to be a nice deal on a Makita combination set (one day deal, down 63% from 524 to 189) and you get a drill and impact driver.
The impact driver has approx 1280 in-lbs of torque (so approx 100 ft-lbs).
I have a average joe 33 gal air compresser from Sears and a set of tools to go with, and 99.9% of the time it sits there doing nothing. It's such a hassle to plug it in, run a power cord to an outlet that will take the amp draw, and then hook up the air tools, that I rarely use it. I'll only bother with it if I KNOW I"m going to be using it alot.
I've thought alot recently that I would (a) use a cordless rechargeable and (b) that I could free up some space in my garage if I had a 2.5 pound electric version over a big-arsed air compressor.
So.. thinking of jumping on this deal, just curious if anyone has used similar tools with success/failure in shade-tree mechanic duties.
At one time, I basically had the same compressor as you (Craftsman 33 gal). I have since upgraded my compressor, but still have a bunch of craftsman air tools that came in a package with my original compressor. I was never impressed with the power of the impact wrench, but I couldn't complain about the tools since the package price was right. Anyway, usually I used a 1/2" breaker bar to get any tough nuts broke loose, then switch over to the air impact for speed.
So one of my friend's sons started working for Rigid, and gave me a coupon for friends and family discount, which, coupled with a big sale at Home Depot, motivated me to buy a kit like this:
http://www.ridgid.com/Tools/R968-Fuego-Compact-Combo-Kit/EN/index.htm
I have been very happy with it, not only for garage stuff, but for all kinds of applications. The nice thing about the impact driver is that it doesn't twist your wrist off once it loads up on torque. I haven't really tested it to its limits, but so far so good. I'm pretty sure that it has much more power than the air impact I have.
Note that the impact driver you specified has a 1/4" quick connect shank (like mine), not a 1/2" chuck. The built-in lights work great!
Only other issue is the battery size...the smaller battery (like mine and the one you are considering) is great for making the tool lighter while working, but it definitely doesn't hold a charge to keep you going long-term on a tough job (like on a construction jobsite, or a lot of heavy-duty sawzalling), but probably not an issue for garage work. fortunately they recharge pretty quickly, and I think you could always upgrade to a double-sized battery if you need one. Mine work okay for me.
Good luck with your decision!
-Mike
Yes I have used them.
Yes I would buy one if I had the cash.
Two things:
Dont skimp and buy the 'cheap' model
buy an extra battery
I'm not saying the one your looking at is the cheap one, tthats just a general rule.
The one I used was a Snap on, retail is a bit more than retail on the one your looking at so i suspect that the one your looking at is a good model
I used it to tear down several Jeepster Commando's that were rusted to death.
It worked VERY well up to and including 1/2" bolts, especially if you applied a little heat first.
I'd say to jump on it :thumbsup:
thanks guys..
Mike.. good point on the 1/4 inch disconnect vs the chuck.. didn't realize that it didn't have the 1/2 in driver until you pointed that out.. tells me that it must take an adapter to mount air sockets, which would seem like a possilbe weak link to me?
still doing some research, though I may not jump on this like I thought I would...
I have used one made by Ingersoll Rand, It was a beast, we used it daily at work to setup jigs and fixtures, I was very impressed with its power.
If you want the best, buy the Dewalt 18 volt, 1/2 inch drive impact. 300 ft lbs of torque. I use mine to remove the lug nuts on all my vehicles. Have sold them to auto repair shops for all their impact needs.
That ones on sale as well.....I was using a Snap-on....worked great.
I am tempted to get the DeWalt....
I have the Makita- it works great. I use it for lots of things- the 1/4 size comes in handy for my purposes. Mine came with the drill, impact, fashlight, two batteries and a case. I got mine last fathers day as a gift- it was priced about $200 at Home Depot. It is the compact 18 volt Lithium Ion set- LCT-2010. I also have a Dewalt 1/2 impact- great tool- no complaints. Since getting these two I usually only use my compressor and air tools to fill up my kids bike tires.
Kyle
