I need opinions
JERSEYJOE
JERSEY JOE
KEARNY
NJ
OK so it's not a Scrambler project, rather a CJ 7 build but I need some opinions. I am building a monster CJ7. Has a 401, Dana 60's and 37's. I was going to use a monster Clark 285 5 speed but I want to change to an automatic.
QUESTION: my first thought is to use a 727 and a dana 300. will this combo fit?
I think !! the problem you will have will be the front drive shaft hitting the trans with any more lift than 2.5"
The 727 came in full size jeeps with drivers side drop
A friend of mine has that set up in his cj7 with 2.5" lift and the shaft is real close
Bit I sure someone on here will be able to give more of an educated answer!!
Hitting
Exactly where does the drive shaft hit? It's a Rubicon Express 4.5 lift with 1 inch body lift.
Are the Dana 60s full width? A stock chevy or dodge axle will clear. If it's a custom axle it depends on where they put the diff, needs to be further off center than the stock dana 30.
I got it backwards
You need 4" of lift for the shaft toclear the bottom
Of the trans !!! WRIGHT ?? Anyone ?!
Automatic opinon
I should clarify. The rear is a Dana 60 the front is a narrowed 44. what is the interference issue? the front drive shaft hitting what?
How about a 999 that has been hardened???
They survive pretty well if you do a good build on them, and they do not have the same pan issue.
Carl
Pictures
Does anyone have any pictures of the closeness of the driveshaft to the trans pan? I am running a rubicon express 4.5 lift.
Take off the quad transfer case and convert it to a Dana 300 ???
That should fit fine,novac adapters considers the t400 to be one of the BESt !!
Automatic
Since I have a fresh TF 727 and a Dana 300 already I think I'll go this way. Currently the Jeep has a Clark 285SV 5 speed which is too big. It does have an 8 to 1 first gear and a .85 to 1 5th. New development is that my GF wants to go with me andI think the automatic is going to be a better alll around choice. Also with my present setup the rear driveshaft is only 16 inches long. Even though its a Tom Woods 1 ton shaft I think the angle is too much anyway.
If I use the 727 and the Dana 300 I am sure I'll need to go with a 4To 1 in the Dana since I am running 4:10 with 37's and the stock 727 and ana 300 will not have much of a crawl ratio wil they?
I want to finish this because there is NO WAY I am missing the Fall ride in Virginia this year.
I can't answer all of the questions, but good to hear this. You do know they moved the dates up on this, right? It's on the holiday weekend, running Saturday and Sunday.
I do like Quadratrac, but it's for milder builds, IMHO.
