1985 cj8 build
Well here is a little axle tease. everything is coming together
nicely. I'll have more soon. here's a few pic's. I have been
busy. I got the wifes car in the garage for winter. but I still
have a ton of parts to sell to make room for other stuff!LOL
7jeeps7kings
Ubolt kit:
Inner front axle shafts:
ford 9" done, dana 44 still needs assembly:
O and I ran into the guy I sold my steel tub too. He
bought a cj8 that need repair. bought my steel tub,
and a new tdk frame and a few misc. parts and bingo
bango he has a real nice cj8.
This was my old tub off the wifes jeep:
And this is how his jeep turned out:
He did a really nice job! And this is why you never
throw jeep parts out! because someone else might
need them and recycle them back into the jeep
world!LOL
7jeeps7kings
update. axle shafts are getting splined. pic's below. more to come.
thanks,
7jeeps7kings
I've followed this thread for awhile and anxious for news...... anything?
it's been slow but steady. The axle shafts are the last thing that needed to
be done to the axles other then paint, fluid, and brake lines. So that was a
huge step. Last year was really a pain just trying to figure out what drivetrain
to run. after finding out the dana 300 was not going to work. i should have some
pic's here soon of the jeep sitting on the new axles with the tires and rims. once the axles
are done it's on to having the body mounted, skid plate, roll cage, and exhaust. So it's
getting there. The axles and transfercase really hurt my budget pocket on this build.
But I have been saving and trying to sell my parts to get enough money to try to get
this thing on the road.lol. I really went through my parts that I have been holding onto
and seperated some of the stuff I really was not intending to sell. but I don't want this
jeep to turn into one of those life projects. so its time to sell!lol.
Thanks,
Drew (7jeeps7kings)
Aloha
On a side note and to add to my above posting:
Well spring is here. But Ohio is still looking to get more snow.
so Jeep stuff is still kinda on hold. I have been ordering parts
and reading stuff on the internet like a machine. I came across
some real cool builds and stuff. One of the more expensive but
nice things I found was this company:
http://www.atrol.com/cablex.htm
they make a little black box that converts the vss signal
to an mechnical speedo. I'm going to try to keep my wifes
cj8 dash stock looking. So this will workout great. I will have
best of both worlds. I can dial in all the stuff into the pcm
(tire size, gear ratio...) and have an accurate reading mechnical
speedo. Or so I hope that's how it works.lol. I still have not called
the company yet.
Also had seen this on trucks. I was looking for a battery charger/tender
for my Jeep cj7 and found The CTEK 7002 was what I needed.
Plus they are in Ohio here's the link:
http://smartercharger.com/battery-chargers/
On another side not I just got back from Kauai Hawaii. And yes
I was there for the Tsunami. which turned out to be nothing (thank god).
But it was a little jeep adventure in itself. The wife and I rented
a 2 door 2009 jk (v6, auto) to get around. it was not bad. I thought
the v6 was had some power if you had your foot into it. otherwise it
was gutless. the transmission kept shifting in and out of gears. The
4.0 tj auto is away better jeep IMO! and I kept hitting my elbows,
knees, and ankles getting in and out of the jeep! I'm about 5'10-5'11
and felt like it was easier to get in and out of cj5 then this 09' jk(and
it had full steel doors). but it did what I wanted. get from point "A" to
point "B", take on some of kauai's trails, and it was a convertible. I wish
I had a friend on the island to ride with. I would have hit more trails. but
I did not want to get stuck the rental place and a couple locals told me
a tow would cost an arm and a leg! here is the pic of the 09' jk
I was a little disappointed. I was hoping to see more cj's on the island.
I only had seen a old cj2a with a make shift wood bed on the back.
two cj-5's: one driving down the road and one rusting/sitting in the
back of a ford dealership. and one cj7. I found this cj7 towing kayaks
down to the river for visiting vactioners like my self. here's pics
But on the other hand I had seen the most lifted trucks in my life
that were DD's. you could tell who was visiting on the island of
Kauai and who was a local. The vistors had BA lifted trucks with
a minimum of a 4"lift and 35" tires. and the island vistors all had
rental stock cars/ jeeps.
I'm glad to be home. I stopped over my cj3b buddies house to
drop of a jeep model I picked up in pearl harbor. and had to take
another pic of his jeep. so here it is.
Well next time I'll get back to the technical stuff and jeep build pic's.
Thanks,
Drew (7jeeps7kings)
axles almost done
Well as promised the jeep is moving right along.
The axle work is almost complete.
heres some pic's of the rear axle(bronco ford 9"):
And here is the front axle(78-79 f250 dana 44):
And I had time to down load more pic's
So far the body is mounted. but not completely. My buddy
is going to tie the roll cage into the body and remove one
or two of the body mounts to give it a more factory look
(not OEM but a clean look. thats kinda what I'm going for).
The door latches (or door pins) are in and the half doors are
on. The dash is mounted, windshield is mounted. The motor
mounts are welded in. The front axle as mentioned above
"almost done". it is together but it needs a drag link arm (from
the steering arm to the ps box. and if you can't tell from the
pic's its a high steer setup). But with no more delay
here they are (the pic's).LOL
it's a little bigger then I thought it would be.
but still I think it has that classic lifted cj look.
It's 36" to the bottom of the door opening
and a few inches shy of 7 foot tall. I'm guessing that
once the suspension settles and it gets the weight
of the roll cage, top, interior... it will come down a
few inches. but it is moving right along. next up for this
jeep is a ladder.lol. no really a custom skid plate, exhaust,
and roll bar. with a few odds and ends things inbetween
bigdaddy rock slidders, mounting the front clip, and figuring
out fender flares.
**I also found out that the factory 5.3l manifold
and y-pipe won't work(with out frame modification). We bolted
the manifolds on and the pipe coming in would not clear the frame.
And the manifold outlet shadowed over the frame to much.
I had wishful think that since I was going ds drop that the oem
manifolds and y-pipe would fit/ work. Again wishful thinking.
Even if the manifolds cleared the frame I didn't think the factory
y-pipe would fit. there are two large cats attached to the y-pipe
check out the pic below:
thanks,
7jeeps7kings
Progress looks great so far! I'm interested to see how the steering ends up.
I used 'Vette manifolds on mine and ran around the front of the engine, 2 into 1 on the pass side.
well still moving along.
I sent the front clip out for sandblast and primer with
no problems this time.LOL. everything turned out really nice.
theres a few spots that might need to be touched up but
they did come off a 1985 jeep! they only did the bent parts
on the hood because they did not want to warp the metal.
I also decided to go with ls2 corvette manifolds. I found
a new set on ebay for a great deal. I need to order new
heat shields. If anyone is looking go this route here is some
info/part numbers:
2005-2009 corvette manifolds
Right side: 2160R # 12603760
Left side: 2161L # 12603758
Heat Shields
12576822
12576823
and these are the ones I got off ebay:
till next time. I can't wait to get
this jeep done.LOL
7jeeps7kings
Well I ended up sending the Ls2 manifolds out to JET-HOT to
be coated. I'm not spending any money on Bling for this motor
so I thought the jet-hot would dress it up a bit. The jeep is
moving right along. My buddy has the skid plate almost done.
He took a unlimited rubicon skid and palte and cut 6" out of
the center. I really just want a stock looking skid.
here are some pic's
So it's still moving along... I'm still trying to figure out how
tj fender flares look on the back of a cj8? and if they will
even work with a fiberglass tub. I have seen some real
hack jobs on ebay and in my google search that leads me
to believe they don't fit right... but my next move on the
jeep: exhaust, top, 6 point maybe 8 point roll cage(and I'm still
researching a simple good look family cage).
thanks,
7jeeps7kings
Are you going to shorten the skid to make it flat? Most (myself included) TJ/LJ owners remove the "shovel" and replace it with a flat skid.
Having wheeled our Rubicon with the factory skid, I can honestly say it can't get much worse with how much it hangs down below the frame.
Nope. I like the stock look and feel of the this skid plate.
I'm really looking for a that stock oem look and function.
This jeep really has no future plans of mudd fest or moab...
This skid actually has more clearance then the oem cj8 skid plate.
It will be modified a little to protect the trans pan a little more.
but otherwise what you see is what you get. Belly up pans have
there purpose. Just not in this jeep. Yet LOL!
7jeeps7kings
Well here is a sneak peak at the tj fender flares...
I think I'm going to just stay with the oem cj8 flares
I think the oem looks better IMO.
7jeeps7kings
and heres some with the weight on the suspension.
Well the 2006 ls2 corvette exhaust manifolds
are back from Getting Jet Hot Coated in North Carolina.
I wasn't going to do it... But the engine need a little bling,
After buying the billet aluminum motor mount adapters from
street performance. Here's some pic's:
Those look great!
Every time I check this thread I see those wheels, and I just like them more and more. One of my new favorites...
