Vortec fuel pump
b.b.chev
Black Forest
CO
For those of you who have done the vortec/ls swap wich fuel pump did you use ?
I finished my swap 3wks ago using the Walbro GSS341in tank fuel pump and have had two pumps fail allowing me ten days of driving time ( those ten days have been well worth the time spent doing the swap:thumbsup:.) . I have been in contact with Walbro and they are sending me new pumps but I am a little reluctant to trust them so I thought I would see what everyone else is using.
Any info would be greatly appreceated.:cheers:
I'm using a factory AC Delco unit, but I can't tell you how it runs...yet.
i ran a factory delco in my tank for 4 or 5 years ..no problems...when i changed to a fuel cell i went with a frame mounted pump..no problems with it either..got it from summit..can prolly find the part number if you need it.
The only things that will kill a pump are a poor ground, poor voltage, or debris getting into the pump. You do have a screen filter somewhere in front of the pump right?
I have checked my wiring at least five times , and it does have a screen on it. I am pretty sure the problem is the pumps . When I talked to the tech guy at walbro he asked for the date code on the pump , after I gave him the code it was within a minute or two that he said he was going to send me the replacement pumps . In the 22yrs I have been a mechanic
I have never ran into this problem . In my past expieriance if you get debrit in the pump or there isn't enough voltage it will blow the fuse . I have my pump fused after the relay to protect everything else. :shrug:
Did you modify your stock sending unit for the pump or did you modify the tank ? I modified my sending unit and there is barely enough room to get it back through the hole . A friend of mine gave me a pump for a 2004 SS Silverado and it is bigger around wich would keep me from getting it in( that and it has two pick-ups).
Do you have a sump or baffle in your tank? I can tell you that these types of pumps do not like to be starved of fuel. I have had a couple burn up over the years due to cavitation. If you are low on fuel and do not have a sump and/or baffle the fuel pump can cavitate and overheat pretty quickly.
Just me .02
The second pump was installed last saturday and hadn't even been below half tank , when it died tuesday morning while warming up in my driveway it was full from being filled the night before.
