114 degrees? Holy crap......
mysunnshine
Phoenix
AZ
So today like every other weekend for the past couple of months I have been working hard on the Jeep getting it ready for the Colorado trip the end of July. But today driving it home, the outside temp was 115 degrees instead of the ususal 110. I found out today that my cooling system gets pissed off at anything beyond 110 degrees. My trans temp hovered at 235 and my motor was at about 220. So now I have one more project to do before the end of next month. You guys that live in cooler areas with humidity don't realize how luck you are. Out here everything has to be perfect for cooling systems to work well because of the outside temps and the lack of humidity. So now it's time for me to put a bigger trans cooler with a fan and send the aluminum radiator out to get cleaned and inspected.. I'll have to blame the trans temps on the 3K stall converter that the prior "builder" installed. If it was easier to pull the trans to put a lower stall converter in it would already be done. Unfortunately I have a flat belly on mine and the motor has to come out to get at the converter. Like everything else these days, lots of things to do and not enough time to do them.... Here are some poser shots while I was checking my bump stops though....
I know you've been around here for a long time, but this the first time I recall seeing your 8. Hot damn (pun intended) that's a nice looking ride!
Can't really help with your problem, though. Have you considerd an oil cooler? Not sure if they really help or not, never used one. Also, Royal Purple makes some crap they claim will lower operating temps, but again, never used it.
Sweet Scram.. but you have to explain to me why the engine has to come out to get at the converter...
I live in this "cooler with humidity" enviroment that you speak of... I would trade it ANY DAY for hot, dry heat. I loved it when I was in AZ with my Scrambler!!!
The guy that originally put the Jeep together clocked the Atlas flat so it has a flat belly with nothing hanging down. The problem is that there is a maze of 2X4 box tubing cross crossing the underside between the frame rails. When they installed the box tubing, they welded everything in and did not flange anything. So the only way the trans and T-case will come out is out the front as of right now. I will cut those out and flange the cross bracing by the time I'm done with it. I refuse to not have the ability to service any part on this Jeep without having to jump thru hoops to get it done.
I had the EXACT thing happen on the way home from downtown Phoenix today. I had to slow down to 55 to make the Scrambler's temperature return to normal. I have the 8274 on the front and the A/C on so I suspect I've found mt Jeep's limit in this oven in which we are living.
My son moved from Charleston SC to Albuquerque NM in December, He works outside most of the time doing sampling, drilling support and enviro remediation stuff. Today we were talking, it's been ONLY about 101 or 102, and he's going to Roswell Tuesday (107, 110ish) so I asked which he preferred, this summer or last (SC, 100 with 90 odd % humidity) Didnt take long to pick Albuquerque, by a couple orders of magnitude...
Thos mountains will be feeling mighty good after Phoenix
OUCH! that sucks... I'd be taking the sabersaw to that! changing the torque converter would be my modivation to get that fixed too!!! :D
Yea but I just don't have time to do that in the next month. After this trip and things settle down a bit, I'll cut all of it out and flange it. It'll be easier to do all of that when the LS motor goes in it.
115
I figured it was AZ. I used to live in Globe AZ and work the Smelters at night and can remember 3-4 in the morning it being 110, hell I remember the airport in PHX would shut down when the index went over 120 deg. I will take the any day apposed to 98 percent humidity. huge well tuned cooling systems were the ticket if I remember right.:crazy::smokin::cheers:
I had the EXACT thing happen on the way home from downtown Phoenix today. I had to slow down to 55 to make the Scrambler's temperature return to normal. I have the 8274 on the front and the A/C on so I suspect I've found my Jeep's limit in this oven in which we are living.
And that is part of why I like flagstaff so much!
LOL, i live in the hot, humid environment. might as well be the rainforest. hottest june in quite some time down here, and consensus is down here that unless there is a severe tropical season here bringing the rain, august is going to be super hot.
the upside about the AZ heat is at least its dry.
Since I can not get the heat out of the transmission, it was time to pull the motor to change the converter to somthing manageable. All of this 2 weeks before the trip too...Lucky me-
