scrambler half soft top build
scrambler228
council bluffs
ia
Hello I have been looking for a soft top for my 81 scrambler for some time, and listen to ideas and priced the old tops that are no longer sold for the cj8 but wanted sometime that looked a little more updated than the old style tops....... I found just the frame work from a wrangler ,,,which also had the sunrider feature,,, being able to fold back the top when the weather is nice would be a plus and still being able to quickly close up the top for bad weather.....so here i am at the start of the mod of the wrangler framework to fit the cj8,,,,, take a look at what i have and i will conture to post progress as i convert it to fit the scrambler
You have GOT to post more pics and keep us updated. I see you have TJ door surrounds to go along with that YJ frame hardware. Nice touch. I always liked th eway the TJ door surrounds seal so much better than the old YJ or CJ stuff. This way you should be able to use TJ soft uppers & mode them just like to fit a hard top. :drool: :woot: :cheers:
half soft top progress
Hi thanks for the reply on the soft top build and i will keep the photos coming,,,, i know from other projects i have done on the scramble how important photos are,,,,,, To feel in a little on what i did so far: first on the frame work,,, took a little hit and miss to get it just right to fit the width of the cj8,,,, then the way to mount as the yj would not work well on the windsheild so that is when i did some mix and matching using the tj side units,,,,, this works good for a number of reasons,,,, they are strong when mounted to the tj sport tube units but if you try this the length of the bars will have to be made longer by about 4 in,,,,to reach the roll bar in the scrambler,,,,,you will be able to see them mounted to the roll bar in the photos,,,,,,, then the frame work also has to be modified in length of the small tube like bars as these were made for a wrangler to the rear and not just for the cj8 cab area,,,,,,,,no big deal but takes some work to keep it square and looking right,,,,,once i got the frame work to set into the top of the tj side units things fell in place and i started to see how the filp could be held in place,,,,,,, i will be posting photos so you can see how all this came together,,,,,, if you have any questions please just ask ias i may leave something out ,,,,, thanks
more photo on soft top build
here are more photos
I was with you until I seen the exhaust stacks. I guess you must be building a half top. Do the exhaust pipes get hot?
Hi no they dont get too hot,,,, you can put your hand on them and not get burned,,,,,also i am working on a ele shut on and off so the exhaust can go either up to the stacks or down below,,,,, wife likes the looks but thinks she gets too much exhaust smell,,,,, as far as a full soft top i guess you could do the same basic idea but would half to get more material but i dont see any reason the front part would not work the same way thanks for the reply
Hello well started the size/fit of the top for the soft half top,,,,,, this is going to take some thinking and work to get right and i am going to be trying some things a little out of the box so to speak,,,,,,,,, I am working with a top i picked up on ebay that was damaged from pavement ends,,,,that is what was on the box,,,,,, little problem with the zipper on the back window which i will take care of latter,,,,,,, but for now it is all into cut size fit,,,,,,,it came with the soft side door uppers,,,,, and the side zip out windows which are two of the key items needed to do this project,,,,,,in the photos you will see the fit of the top to the soft uppers on the doors is key to using the side windows take a look more to follow
I think I am getting it now. At first for some reason I was thinking soft top was from a YJ, but header is a TJ as are door surrounds. Then for a 1/2 top with the support bard going from windshield to roll bar I was trying to visualize how you were going to make the top fit with those bars in the way, but I think I see you are planning to cut holes in the top matrial for the support bars to go through. I like the way you attached them to the main roll bar with U-bolts. I would like to see more pics of that attachement as well as how you fastened the TJ qucik connect clips to the CJ windshield. I had thought about how to modify the header from a TJ to fit the CJ & YJ to do away with the windshield channel. Looks great! If I get to pass through Council Bluffs I must stop & see it. I am about 7-8 hours east of you but planning a trip out Wset in the Fall, but may take a more ssouthern route. We will see & I'll ping you to see if you would be around if I get to head your way. But definitely am following this build. Looks fantastic so far. I also have seen pics of your Scrambler in other posts & liek your seats- where did you get them with the CJ-8 lettered into the head rests?
thnx, Danimal :thumbsup:
soft top progress moving right along
Hi again working hard on the top and hope to fit the top on by end of this weekend,,,,, will get the photos you asked for soon,,,, on how the clips mount to the windshield and yes the top will have two holes in the back for the sport bars to pass thru,,,,,I will be showing how i did that and the holes will also be reinforced with some additional pcs cut out of left over parts from the top..... take a look and i will be posting more of the top build sat and sun thanks
some more photos of work ,,, getting ready to make final changes on some of the pcs of the top and get my wife to sew up some the the cuts and put the two pcs of the top together
Hi well while the wife is working on putting the top pcs togther for me i thought i would put on the bikini top just to see if it would still work without any problems with all the new hardware i have put on over the cab,,,,,, see photos no problem still works ok,,,,,, so with this set up i can still use it on really nice days,,,,,,, also have been busy doing some painting to the steel half doors and a few other items for the jeep that i will be posting latter,,,,, will be back with more photos of the soft top latter today when i fit it on after being sew up to see if i will have any problems with the filp top
soft top progress top
Hello well wife has it all together and here are the first photos of it on the jeep,,,, this will have some work to do and some snaps to install in several places but very happy with it.......have a question that maybe you guys can give me some feed back on,,,,,, when i have flip top open and or soft top side windows off ,,,, or even no doors at all and top of course on am i going to have any trouble if the back window is left in...... little worried about wind catching the window coming in from the open top and or doors.......the back window zips completly out and i am still working on the lower mounting of the window,,,,,, it comes with a kind of slip/in bar unit that was intended to be mounted across the rear of a wrangler and when unziped, would just be rolled up at the bottom area at the rear of the jeep,,,,,,, now what i am thinking is since it can be unziped and removed,,,,,,,mybe i would attach it at the bottom with snaps instead of the bar unit so i can remove it all the way and store it in a tube to protect it,,,,, seems rolling it down behind the seats in the scrambler would scratch it up,,,,,, what do you guys think on this also thanks,,,,,
soft top progress top photos
here are some more photos
Wow, that was fast! Very cool project! How does the top seal along the tops of the door surrounds? How does the hole for the sport bar work and seal?
The back window is made to seal against a straight edge which you should have. What if you just snagged the two brackets off a wrangler and mounted them to the top edge of your bulkhead? Seems like it would be the right height since it's the same level as the sides of the tub. Might need some foam seal tape on there somewhere but I would thing it would be easier than switching to snaps.
I actually purchased a YJ full top years ago for this exact project. I never got past the point of mounting it for a quick test fit. So, unfortunately I never was able to get answers to my similar concerns.
Your post has definitely moved this project back up my list.
BTW- (off the topic) What setup do you have for your wiper blades?
Hello again,,,, thanks i am very happy with it,,,, still have a few small items to take care of,,, will be working on them today ,,,, and to try to answer you question,,,, i will get some photos and post them later today showing how i am sealing the top against the top of the windshield and how the top hold over the sport bars,,,,, i also think i do have the metal pcs you are talking about that came with the frame to hold the slip thru part on the bottom of the back window but i still think if i do use that i will not be able to remove the back window,,,, it i think will just let you roll the window down to the bottom,,, but i will get them out and take a look at them,,,,,,the seal for the round holes for the top to fit the sport bars thru to the roll bar are just a tight fit but if you look at the photos you will see i cut two round circles about 4 in and used a heavy duty bonding glue to double of thickness of the material ,,,, their does not seem to be any stress around the holes so i think it should be ok,,,,i still would like to hear from you guys on my question on any problems with the wind coming into the cab area if and when i have the top open and windows removed and doors off if i would leave the back window in...... is it going to catch a lot of wind and cause any problems,,,,,, very soon i will be ready to take it out for a test drive to find out,,,,, just would like to know what you think on this,,, or should i allways remove the back window if i am going to have the top open,,,,,, it is a little hard to get the window in and out due to the room around the seats,,, so if i dont have to take it out all the time,,, it would be better,,,,, maybe i am worried about something at wont be a problem anyway..... thanks
Hi well been working hard today to get some of final items taken care of,,,,,the following photos should answer most of your questions,,,,, if not please ask,,,,, today i added a couple of snaps and did some glueing on the inside of the top where the two pcs were sewed together,,,,,did a couple of small additions to the inside of the top where the metal bow helps hold the top up,,,,,still have to work on the back window and the window mount,,,but will be putting the top back on yet today,,,,, take a look at the photos,,,,, and also in reply to anyone that would get new council bluffs iowa (omaha nebr) area ,,,, please do email me and we could see if we could get togther ,,,,, i will be posting some of the other projects i have done and still plan to do to the scrambler soon so be looking for them
more photos of soft top,,,,,the question on how the top is held on to the sport bars,,,, the photos showed the top on the front leading edges a heavy type plastic strip that is sewed into the top that tucks under and into notches that are molded into the sport bars units,,,, also the photos show that part of the material that covers the tj side panels are attached with a snap at the bottom (may add another on each side not sure if they are needed yet) and also with varcrow which is used a number of places on the top,,,,, these two planels i made from the two side windows that came with the top,,,,, just had to cut the front part out then wife did the rest for me,,,,,,as i said before i had to think a little out of the box and use parts/pcs to fit everything togther,,,,,, the following are more photos of rest of top as it is now ready to go back on,,,, thanks
