Starting Problems
TXJEEP
Copper Canyon
TX
I am pretty new here so my apologies to the moderators if this is in the wrong place.
I am on day 3 of ownership.
Day 1. My Scrambler was driven onto a car hauler, delivered and at that time would not start. There was some fuel leaking from the fuel pump so I replaced it and it started right up and ran great.
Day 2. She wont start. Turns over fine just does not want to fire up as if there is no fuel getting to the carb. I figure may as well replace the fuel filter because maybe there is something settling and preventing good flow. Replace the filter, she fires right up and runs great.
Day 3. She wont start. What he heck? Any ideas? Is this a cold start problem that I can try different scenarios with? I have been told that it is easy to flood these carbs but any advice would be greatly appreciated.
Thanks
Welcome :wave:
Is there a choke on it? Is it electric? With the engine cold, look down the carb, is the choke open or closed? If open, try closing it and seeing what happens.
If the choke is present and is closed when cold, do you have any starting fluid? Wonder what happens with a shot of that in the carb when it's refusing to start. If not, you can pour a small amount of gas in the carb and try to start it then (stay out from under the hood when doing so) and let us know what happens there.
You can also disconnect the fuel line from the carb, hook a hose to it and run that into a container while cranking to see if you're getting fuel on crank.
I'm sure others here will have thoughts to share as well.
Also moved this to the engine forum for you :)
I think she was just testing me. I went through the recommended steps above (thanks so much) and all appeared normal. Interesting enough, the problem went away. She starts right up now and runs great.
Cool! Love those kinds of problems ;)
I would still be curious about there being some crud in the tank that's plugging the pickup intermittently. SOMETHING had to be happening there to keep things from starting. Hopefully it keeps on keeping on for you, but it sounds like dropping the tank might be in order if it rears its head again.
Out of curiosity, have you filled the tank during any of this leading up to where it's working now?
Might be worth sticking an extra, clear fuel filter in the line before your normal filter just to easily watch for any crud/rust that might indicate that this is the case.
Things were going great until yesterday when it started normally but died and would not restart. There is good fuel flow all the way to the carb but no smell of gas from the carb even after several starting cycles. Ultimately I get it started by pumping the gas peddle a lot which I think freed something up. I am not capable of pulling the carb and rebuilding it and I think that was done a couple of years ago anyway. Should I just try some gumout or something like that.
So when you say there's good flow to the carb, you pulled the fuel line right at the carb to check while you/someone was cranking the motor over (obviously while catching the gas from the line in something suitable and being very careful)?
How long was it running before it died on you?
After you got it started with all the pumping of the pedal, it stayed running fine?
I'm not the carb master by far, just trying to think of all the possible questions.
Oh, and you're definitely able to pull, clean and rebuild a carb, it's one of the simpler things you can do, just seems intimidating ;)
Completely agree with everything BW's said, but especially this. Unless you have no tools, no hands, or are legally blind, you can do it. Apologies if any one of those applies.
It could be choking out (check the choke as BW suggested initially), it could be an intermittently clogged fuel line - at the pickup, at the filter, etc. More than likely, it's something electrical...CJs are known for their electrical fallibility and it seems that only after you've ruled everything else out and spent thousands of dollars replacing and rebuilding everything do you find that loose lead at the distributor. :banghead:
I had zero experience with mechanics when I got my CJ, but over the past year have learned a ton, all it takes is one part bravery, one part patience, and one part ingenuity. That and this forum will get you a long way!
Wow, more great advice. First, yes I disconnected the fuel line and it pumped well when starting. Caught the gas in a container, reconnected the line, dumped the fuel in the carb, turned it over and it ran for 2 seconds.
Now here is the funny thing. I don't know how this is supposed to work, but little flap on the carb opening will not close unless I move the throttle linkage and then move it closed. Could this be a problem with the linkage binding on the electric choke?
Problem is that at the times it won't start, I can see that there is not gas shooting through the two little jets inside the carb. I am pretty sure it should no matter what position the choke is in, correct?
Now eventually, with some starting fluid and my pissed off wife at the ignition, it eventually started and then ran like a champ.
Intermittent problems are the worst. :banghead:
Sorry, one thing in the past couple of days. I swapped the battery to an Optima Red Top that I pulled out of my previous truck. I was wondering if it was possible that the cheap battery may have been ok on voltage but lacking in cranking power. Again, last 5 starts uneventful. Cranks right up and runs great.
When it's cold, and without doing anything else to the Jeep, what position is the "flap" in. That's the choke and when cold it should be closed to allow you to start it and then open gradually as it heats up.
Then we have a suspect. When its cold it is wide open and in fact it is always wide open. I am not able to close it unless I jog the throttle linkage and then it will move but it also will not stay closed. It simply flaps back open unless I hold it closed.
Sounds like I better sort this out before the weather cools down or this will get worse.
Ah, back to the choke. Definitely sounds like it's a problem to me. One thing to try, there should be a wire running to the choke, unplug it and see if the choke closes after a while. It's possible (though unlikely) that it's gotten hooked directly to a 12V battery feed and not a switched ignition feed. That would be causing the choke to stay open and would be draining your battery (slowly) all the time.
Personally, I liked when I pulled off the electric choke and simply installed a manual one I controlled from the cab. Never had to worry about it after that. All part stores will sell a manual choke kit.
Ditto. Takes a little time to learn how to use it, and you have to adjust to the changing temps (i.e. open sooner in warm weather, open later in cold weather), but after a while you get used to it. I loved my manual choke.
unplugged the wire feeding the choke and it stayed open. I think I will take the advice on the manual choke. I even like the idea of it. One less thing to go wrong in the future.
Question is how much of the components of the electric choke come off to install the manual? I have 0 mechanic training and I am still a bit intimidated looking at the structure.
Which carb do you have, and if you don't know - post a picture up and we can go from there. In fact, either way post a picture so we can refer you back to it. I'm only familiar with the MC2100, but there are plenty of others here with other carbs who can help.
Do you have a voltmeter to check the voltage on the wire that you unplugged? Just out of curiosity. It should be a switched 12V feed, only on when you have the key in the run position.
On the manual choke, very little should have to come off, basically just the thing that the wire plugged into. It's just a coiled spring that is keyed to the choke shaft and is supposed to open the choke as it is heated by the power from that wire.
You'll have to attach a bracket at/near the carb to hold the choke wire, attach a fitting on the end of the choke shaft to attach the choke wire and then install the choke handle/bracket inside the cab to pull to close the choke or push to open it.
I attached the handle/bracket in the cab to the lower edge of the dash, I reused one existing hole and drilled one new one. I think I drilled a new hole in the firewall for the cable to pass through and the bracket at the carb was pretty simple to figure out when you had it in your hand looking at it.
Pictures of your carb and choke would be helpful.
I don't know the model but would love these pictures to reveal that. Here are the photos of front and sides.
Just my 2 cents worth.
Based on my experience with chasing a similar issue that I thought, and 2 mechanics thought was fuel based... fuel pump, trash, water, etc. Turned out it was an intermitent ignition issue that was not resolved with new coil, module, etc. Since replacing with the DUI ignition system about 8 months ago, I have had no problem. Just saying... I would not rule out an itermitent ignition issue.
