Are the lug nuts loose or is the whole wheel assembly loose? You might want to jack up that side and with the tire off the ground, grab it at the 12 o'clock and 6 o'clock position and see if it moves. If it moves it most likely is a wheel bearing. I wouldn't advise driving it until you find out the actual problem, loosing a front wheel at speed would not be a good day.
I lost the drivers side rear... good thing it was on a country road and not far from my dads house.. whole axle shaft slid out of the housing attached to the wheel.. BAD DAY.. approx $300 for local 4wd shop to fix it cuz i didnt trust anyone else to do it..
I had the same thing happen to the same wheel. Never heard any noise from the rear end. 11 'o clock at night and 15 miles from home. The end result is I have a dana 44 rear axle now.
