Ok, what's the differences in the CJ8 tub and a YJ tub. The reason I ask, I know where there's a couple of YJ tubs that are rust free. My CJ8 needs a cab floor for sure, how much of the YJ could I use? I know a CJ8 is a CJ7 with an added 10" and some people tell me the CJ7 tub is the same as a YJ. Some tell me there are differences like a couple of frame mounts. A CJ8 cab floor is $450, I can buy the YJ tub for $400 or less.
Yes you can get a whole front floor for $450- I have seen them less but still just under $400. Also then the rear floor is another $450 or also seen just under $400. But still with shipping etc you would be looking at between $8-900 just for the floors. Then what shape are your side panels & rear corners ? The CJ&7 & CJ8 are the same. The YJ is also the same profile except the holes are diffierent between the YJ & CJ7/8- gas filler changes sides. But some food for thought for you. Let us know which way you decide or ask more questions if you need to. But make sure to TAKE & POST LOTS OF PICTURES!
Good luck in either endeavor, and just so you know....I would cut the body in half and graft it, but I am partial to doing that
