I just bought new shifter knob and transfer case knob. The insert/button that goes in the middle that shows the shift patern/transfer
case pattern came separate. How in the heck do you get those inserted. Been fighting with these darn things.......
I just bought new inserts for my knobs also and had the same issue. If your inserts are the same as mine they have a piece of black molded plastic on the back and sides. I used the sharp point of my pocket knife and carefully pryed the insert out of the molded piece. It then fit into the knob perfectly.
If you use some sort of lube like that silicone based stuff that doesnt smell or even dish soap or something like that they will go in alot easier. Then just wash off and set outside to dry.
