Sway bar links
johnlt44
Chattanooga
tn
I put some YJ 3 1/2 " springs on My Cj8. whew! Now I need to get the sway bar back on
going with new bushings but what about the links? I dont think the old ones will work
any clue. Thanks JT.:crazy:
You can buy the extended disconnects available from several companies. The sway bar links from a Waggy (I know late '70's) are longer and will swap in place of the shorter CJ links.
I took the sway bar off mine...as a matter of fact every cj I have owned i removed it when i lifted...lift springs tend to be stiffer and i never noticed a difference with or without..drive it a few days without the links and see if you even notice its not there.
Thanks Scott.
I have had people tell me to do a panic turn at low speed to see how in reacts then increase the speed. I hope I will not need it but better to ask.
My last lift was a 4" Trail Master and I did not need to use a sway bar and it was pretty stable on the road. This winter I did the MORE shackle reversal and went with a 5" BDS lift. I set it up without a sway bar and there was a big difference. It was like a boat going down the road so I installed a sway bar with quick disconnects. It is much better at 60mph with the sway bar. Be careful on the length of your sway bar links. If they are too long they can push the sway bar high enough to rip the break lines off.
My Scrambler has the Old Man Emu 3-4" lift with the Wrangler Spring conversion with Sway Bars Links that have the quick Dis-connects. This would be the best of both worlds.
I have always thought that if it came from the factory like that, you might want to do the same for the highway especially. Going offroad, then pull the Dis-connect pins and off you go.
Thanks for the help. Will I have to replace the spring plate to use quick disconect links?
