Cool in-the-Jeep tool thread
bigwalton
Alaskan Postal nutjob
FORUM MANAGER
Dexter
Ok, figured we should have something like this around here and I found a neat addition to the permanent Postal toolbox today to start it off.
Ace hardware had this 4 in 1 screwdriver that has just replaced a few old ones I stashed in the box. Freed up a lot of room. I'd like a nice mongo-multi-bit one, but this was just $3.99.
ImageUploadedByTapatalk1347342929.779954.jpgImageUploadedByTapatalk1347342974.779583.jpg
What are your cool in-the-Jeep tools?
Yes!!! Zip Ties are required before any state will let you purchase a CJ. There's your fun fact for the day :-)
The number of things I've fixed with them is insane. Last two were attaching the steering stabilizer to the tie rod after the axle end nut fell off somewhere and using a complex intertwined setup of the for reattaching the tranny end of the shifter cable on Matt's LJ when at the Bantam show after the shift lever connector decided to disintegrate.
View attachment 28493View attachment 28494
That is the same 4-in-1 screw driver I keep in the pocket of my turnout coat on the fire department (it is actually a 6-in-1, the ends of the "tube" can be used as nut drivers). Very handy. I also keep a leatherman tool and a spring loaded center punch in there. Amazing what those three tools can do.
I have a bluetooth OBD2 code reader for my iPhone.
I also have a gamma radiation detector in the Jeep... (seriously)
I also keep a leatherman tool...
Ditto that, have my older one permanently in my console and if I'm wheeling I have my nicer one on my belt. Definitely another must have. The screwdrivers on them are ok in a pinch, but the combo of the leatherman and this 6 in 1 :D Screw driver is great!
Hammer
Screwdrivers
electrical tape
leatherman
flashlight
small socket set (Craftsman on sale for $10 a few weeks ago)
Adjustable wrench
zip ties (lots of them)
All that goes in my Tuffy with room for CD's and koozies.
Two 5.56 ammo cans.
Can One: (2) 5000lb cargo straps.
Can Two:
(1) surefire flashlight
(1) set Allen wrenches
(1) small set craftsman sockets
(1) bag small zip ties
(1) bag xl zip ties
Misc screw drivers
(1) Leatherman Mutt
(1) roll electrical tape
(1) small roll 90-mile/hr tape
(1) small bag misc nuts and bolts
So far I've had everything I need...now that I said that I will most assuredly have some issue today that will make it obvious that I am deficient some obscure, but momentarily critical, tool--which I will promptly add to can#2 once discovered. :shrug: :). Life is good.
Yup, you're now screwed :rotfl:
Misc screw drivers
SEE! You can free up room now for the stuff you're going to find out you needed after your "I've had everything" comment by swapping these out for my one 4 in 1 screwdriver!! :D
The leatherman is a definite. That was the only thing taken from my console when it was broken into the first time. I was pissed. But the idiot did not know what he had and tossed it in my front yard. Thank you idiot. No loss.
My other must have is a ratchet strap. Oh and duck tape!!!!
In my GTO I used to keep one of those As Seen On TV Ginsu knives. That dang thing would cut through anything.
Here's a question:
You can only have one in your Jeep: duct tape or zip ties?
I think I'd actually rather have zip ties. They can be structural to a point and I've used them probably 10 times as much as I have duct tape to fix Jeep junk. Some of the things might have worked with duct tape, but probably not nearly half and the others couldn't be done (fixing Matt's shift lever/cable connection on his LJ like I cited earlier is a perfect example).
Thoughts?
Putting the 4in1 on the wish list. And for the record I didn't need anything today. So I'm really hosed tomorrow. :)
Regarding the duct tape vs zip ties-- i vote heavy duty zip ties, no doubt.
Zip Ties for sure. Got called in once from the garage when my in-laws came over, made myself a belt out of about 5 of them - was supposed to make me look more respectable with my *** not hanging out - not sure it did though
zip ties... but.. you guys have never used Nuclear grade duct tape, have you? That stuff is awesome, sticks to everything and does not leave any residue when you pull it off.
In my console i have.
I have a Gerber multi-tool (like leatherman) that I got from work...
Swiss Army Knife
wind proof lighter
