1984 Scrambler-whats it worth??
scrambled eggs
chapin
sc
IMG956945 (2).jpgIMG_8779.jpgIMG959014.jpgIMG959290 (2).jpgGuys,
Curious as to what the crowd thinks this Jeep is worth. Here's the information:
1984 Jeep Scrambler
258, w/ 4spd. T-176
model 20 rear end
dana 30 front
stock motor: mileage is in question. Gauges other than odometer would not work so previous owner replaced. old odometer shows 45k miles..only few hundred on new. could have only 45k but could have 145k...was used as a camp jeep prior..Jeep sat up for 8 years +/- so had some leaks once it was started up. I have the stock rims for it as well as stock carpet kit Currently working on a rough idle..carb was rebuilt bu t something's not quite right.. any suggestions on replacement carbs? Jeep does not appear to have any bondo in it.. only a few small holes in pan that have been ground and plugged w/ glass. Heat does not work....the following is new:
Radiator, water pump, tstat
battery
cd player/ speakers
grabber tires/rims and rusty's off road lift (4") w/ drop pitman and ss brake lines
new receiver hitch
clutch: resurface fly, gaskets,etc
new hubs
new brakes
new steering shaft,steering box
rear view mirror, steering wheel cover
new fuel pump
alternator
starter
Drivetrain has been resealed
valve cover has been replaced
antenna
shocks (new)
few small leaks...5-6 drops here and there
Believe that is all the info that i have... Please redirect this if i am posting in the wrong area.thanks
TRIED TO UPLOAD PHOTOS BUT SAYS EXCEEDS MAX SIZE FOR SITE..LMK HOW TO UPLOAD. REALIZE POST IS PROBABLY WORTHLESS W/O PICS....THANKS
Just looking at pictures, I'd say you were in the $10,000 + club. Not that I got the cash to offer that...... It's always easy to spend other people's money.
You might want to correct to a Dana model 30 front, it wouldn't be a 35 (nor would you want it to be). I'm a bit more conservative at $8k +/-.
Depending on when the odo broke, <100K is probably correct. 84s had a "1"00,000 digit, so it would've turned over. Not sure when the change to that style odo happened, but maybe the mid 82 run?
I'd consider $10K. Have you sorted out why the heater doesn't work? Mechanical or coolant/heater core related? Do the hoses get hot?
Is this your Jeep or are you looking to buy? In the third picture you posted, on the passenger side of the tub right below where the "Jeep" logo is stamped, the tub appears to have slight bulge here. Since this area is common for rust and the Jeep has fresh paint I would check this area for rust. If the person who did the the paint and all thought it was okay to repair the pin holes in the steel tub floor with fiberglass, I can almost guarantee they would have no problem using bondo to cover rust damaged areas. There is only one way to properly repair rust and that is to weld in new steel. Fresh paint on a Jeep that has signs of previous rust, such as the pin holes in the floor, always scares me as a potential buyer. The steel dash panel appears to not have been pulled and painted; I've never understood why people do this (or when people paint the dash but don't pull it out and they paint directly over the torx dash mounting bolts, but that is a whole different story). Has the underside and engine compartment been painted? Any pictures of the underside, engine compartment, fiberglass patch work in the floors, frame, etc? Fresh paint on a Jeep that has rust repair and didn't have the tub pulled to properly paint all surfaces would have me a little worried. I would prefer an original paint scrambler with a few pin holes than a scrambler with fresh paint that could be hiding other issues. Looks very solid but its hard to say what has been done (or hasn't been done) under that fresh paint. Do you have any pictures or info of the Jeep prior to paint? It would definitely help when assessing a value!
Appreciate the reponses..
Walkerhound, are you saying that 84's had a 6th digit so i would have read accurate mileage at 145,xxxx? my old odo only has 5 digits w/ the partial for xample: 45,608.8 . I bought the Jeep and was curious as to what its value may be. Per the previous owner, there has been no replacemnt panels, no bondo other than light swipe on hood and i cant seem to find any areas that appear to have bondo. I see that blurry spot youre referring to and i ll double check but when the sunlight hits it, nothing appears to have bondo.i llt ry to find some more pics that will fit below the sites max size. i have not traced the heater issue yet. The hoses get hot so i m thinking it may be something as simple as linkage or blower motor....trying to get the carb resolved so i can drive. debating on fooling w/ the stock rebuilt one or just buying a new one and bolting on to eliminate the inevitable. Any suggestions on replacement carbs? weber or stock? Jeep just used for joyriding andtoting a cooler around at this time.
unfort, i do not have any pcitures prior to paint. owner said that jeep is 99% original and no bondo. not sure why they didnt pull the dash panel other than the fact they were too sorry to do it. will take a few more pics of engine compart/under carriage for ya'lls analysis.. Unfortunately, it appears they got teh stock color wrong on the repaint...
thanks
Great looking Jeep. I'd put it north of $10k... maybe in the $12,500 area.
I know why they left the dash unpainted.... 'cause it's a hassle removing all the gauges, HVAC controls, etc. ;-) A friend painted his Jeep like that - yellow Jeep, red dash. Looked like crap and I gave him sh1t all the time for it. Yours looks much better though.
Quick check for the bulge under the "jeep" logo - a thin refrigerator magnet. Strong enough get through paint, but not Bondo.
Go with the MC 2100 or 2150. Easy to find in a junkyard or on ebay. Better performance.
Will throw the Clemson Tiger paw around any suspect bondo areas and see if my eyes are deceiving me. Next question is: need a rear seat w/ belts to haul the 15 month old around. Any suggestions on the following:
a) two nutmeg seat covers for front (mfr and website?)
b) rear nutmeg seat w/ mounting brackets and belts?
c) Anyone ever put the belts that allow car seats to just clip to them ? i.e...new vehicles have U-hooks that the carseat just clips onto....rather than running a seatbelt thru the seat itself... not sure if anyone has this experience.
d) not sure this thread is in the right forum
Yep - there's a thin roller there for a 6th digit. Anything older than 82.5, I think, will only have 5 - like my 81 which has 46,000 original miles ;)
I'll second the MC2100/50, if you like carbs. The MC is easy to deal with, but I would advise against purchasing from the guy on eBay. He's legit, provides a great product, but you can do your research on the carb and come out ahead if you like to tinker. If you don't like to tinker, by all means buy one from ehrmannmp ($300+).
If you don't like to tinker at all and have deep pockets, I'd recommend a Howell TBI kit ($1300) or Mopar MPFI ($2000+) kit. Both provide fairly hassle-free maintenance, better fuel economy, reduced emissions, and you can do the install yourself if you're handy with a wrench.
You can get Laredo nutmeg seat covers for $1400: http://www.ebay.com/itm/Jeep-CJ-NOS-CJ-Laredo-seat-covers-CJ-nutmeg-seat-/350661755507?pt=Motors_Car_Truck_Parts_Accessories&hash=item51a511c273&vxp=mtr, but my guess is you can find something more reasonable if you don't care about looks. You might even consider buying a new set of seats and set those originals in the garage until you decide to sell if that ever happens.
For what it's worth, I don't think that dash pad is original, you've got vent windows and the dash pads on CJs with vent windows had different ends to allow you to open the window vents. Not a big deal - you can always sell it to me, I'm looking for an original nutmeg dash pad ;)
It's a beautiful Jeep, you should be proud to own it.
That is odd - I'm (now) almost 100% certain an '84 should have a 6th digit, but you're right, I don't see a sliver there for it. That tells me it may have had an odo swap at some point.
Also, an MC2100 will require some modifications to work with your stock air cleaner. That air cleaner looks great, so if you decided to go with an MC, it would be well worth the mods (less than $20 in plastic spacers) to get it to mate up.
See also this post over on JF: Speedos from an 84 and an 82
It looks like you've got shoulder mounts for your belts going through the top, so that much is 82.5+. I wonder if the PO did a complete dash swap during the rebuild? It's still a great looking CJ, but the story is getting a little more sketch.
If I remember all the diffferences in my 70's vs. 80's Jeeps.... if it is a 90 MPH speedo then it is older, 85 mph it is newer and usually has the 6th digit.
So, if you have that tagged as an 84, you should have an 85 MPH speedo in there, but from what was said above, yes, it could have received a new speedo at some point...
Do you have a carfax from it to see about the mileage?
any good direction on where to purchase a MC2100 as well as plastic spacers associated w/ Air Cleaner? my time is limited w/ work and family. just looking to get her back on the road asap..in perfect world, bolt the carb up and ease on down the road.
You'll also notice that the 83+ have temp and fuel icons, while the earlier years have "Temp" and "Fuel."
As far as an MC - sounds like you may be better off buying from the eBay guy with your time constraints. See here: ehrmannmp's MC sale posting
Contact him, tell him what you have and what you need (spacers, etc), your location (elevation dictates which jets he uses), which manifold you have, electric vs. manual choke, and he'll probably have it all on hand, it'll look brand spanking new, and he'll ship it out fast, including installation instructions in word doc form. They're pretty self explanatory, I found the installation really straight-forward. As long as you won't ever have to worry about emissions testing, this would be a cost-effective modification.
Be forewarned, though, he is VERY good at communicating prior to the sale. If you have questions post-purchase, he rarely responds. You'll be better off posting here, many of us have done this modification and can troubleshoot as needed.
Per the VIN its an 84 out of toledo. So are we still in question as to whether or not the 84 should have 5 or 6 digits? per your certifiable jeep links above, the 83 has 5 and 85 has 6??
This jeep was not rebuilt but only reworked where needed to include list of parts at start of thread. My curiousity is the actual mileage....and now, whether or not odo has been swapped twice. w/ its condition/from what i can tell, i m leaning towards only once.
Nope - his 83 is just ultra-low mileage, right CB ;) You can see the sliver for a 6th digit just to the left of the first "6."
You're probably right, SE, swapped once +/- the whole dash. Speedo replacements aren't uncommon, and usually a result of a failed temp or fuel gauge. With the added benefit of potentially lowering your mileage, of course ;)
