How to mount auxiliary lights to roll bar?
ksherbine
Somerset
PA
What's the best way to mount off road lights to the roll bar? Is it best to drill the bar, or do
you need a mounting bracket that goes around the bar? If so, what's the diameter of the rollbar (I'm at work and won't be able to measure until the weekend).
Thanks,
Kirk
The rollbar is 3" tube according to the original brochures I got yesterday. And I would either get a mount that wraps around the bar or weld tabs to it. But I would personally not drill/tap into the bar. My opinion.
What about running the wires? Would they be run in conduit on the outside of the bar, or fished through a hole?
Thanks,
Kirk
Either way I suppose. I am looking to add a dome light to the roll bar myself and will probably run them along the outside in some small tubing. Not perfect but I may use battery powered. Not decided. I was considering a small hole and running the wires out the bottom foot plate of the roll bar, but am reluctant to drill a hole. But i may get past that hang up I have.
I drilled a hole then welded in a nut and worked perfect. Ran the wires inside the
Roll bar for a clean look.
