I don't have any more pics of the rotisserie. I took it apart and stored in the shop for another project. I had never built one before. I just looked around on the internet and found some free plans. It was really easy to build. It is the only way to work on a jeep tub. You can spin it any way you need to cut and weld.
Clean scrambler. Your panhard seems a little on the short side. Everything I read seemed to point towards as long of a panhard as possible. I am sure you had limitation with packaging. This probably drove the mounting position. I am no expert but from experience on another rig I owned I would think that you would want your lower CO mounts oriented with the bolt going back to front instead of side to side. I think over time the lower portion of the CO's will see some damage. Keep up the great work. I love the build.
Something like this would be money for the lower shock mount you have.
Got a lot of work done today. Winch bumper and D ring mounts, shock reservoirs welded on, fender flares mounted, spare tire and hi lift mounted, seat belt tabs.
As for the wagon. I collect Willy's wagons. I have a 63 Traveller, 62 traveller and a 62 Parkway. The one in the pic is the 62, I found in El Paso. I am in the process of restoring the 63, it is in the process of being painted. I keep putting my painter off to paint the scrambler. And behind the wagon is a 64 3B.
