Jeep Acceleration issues
There is a lot of information that you are leaving out to accurately diagnose the condition.
1. What timing numbers do you have at idle? How much right off idle where you're having the hesitation?
2. Have you checked the A/F when it's hesitating? Is it a rich or lean hesitation? Does it snort thru the air cleaner?
3. Which PV is in the carb? Don't most of those have dual-stage power valves?
Everybody ends up changing the ignition when they do this MC2100 carb change. The problem can be sluggish mechanical advance to improper vacuum connections(full vacuum and not ported).
already changed the ignition when changed the distributor. do not know which or how many power valves i have...i emailed mike (gronk) but no reply in last 2days... Book said 8 degrees before TDC at 1600 RPM with vacuum line off dist. With vacuum line plugged. What do you recommend. Currently on full vacuum.
I ran my motor with a HEI at 12-14 deg at idle with 28 deg total mechanical advance all in by 2600RPM. That's where it made the most power on the dyno. I recall most of the 2100's have a 2-stage power valve where it will partially open at 10" of vacuum and fully open at 5" vacuum. You need your vacuum advance hooked to ported vacuum and not full vacum.
So when you are having these issues and you opened your hood to check your timing at idle, what timing do you observe without changing or doing anything?
Did not have time to fool w/ it this wkd.. Got the jeep at a cousin's getting a new clutch/throwout/etc... appreciate the help so far..be in touch..update in regards to Mike w/ Ebay...no response after two emails... initially was responsive and offered to send a new carb... but no response from last two emails.. i have not given up on him completely just yet..
Bump. Any luck? I realized I don't have an evaporative canister. I get whoosh and it runs better without the cap. After I fix that I'm going back to work on grok 2150.
I found that i had two issues that have since been corrected.
1) carb that originally sent was defective in some sense. To Gronk's credit, he sent another one after about 6-8 weeks (believe he was ill)..he sent a rebuilt one which had a larger power valve than the previous (new)... he mentions these carbs are new, however i believe they are all rebuilt as who would be mfr'ing new MC's unless its from China. Put the new carb on and did fix the fuel issue i was having.
2) Found that my timing was off w/ HEI upgrade..did have to adjust and i believe it was somewhere close to the setting that mysunshine listed above..i wrote it down in the book but will ahve to check later to see what the settings are...
while in shop i had RMS replaced, valve cover gasket, new clutch throwout bearings,etc, and a few other odds and ins.Also, went back to the electric choke in lieu of manual and have had no problems w/ it.
