4"+/- Surface Mounted Round Jeep Turn Signals or Similar??????
scrambled eggs
chapin
sc
anyone know where to find a surface mount turn signal that matches (or is at least relatively similar) to the Jeep's 4" turn signals in front grill? in my infinite metal fabricating wisdom, i covered up my turn signals w/ bent plate in order to mount the 8274. i added some LED strips but it looks like boogered anus. i'd like to install some in the front bent plate to at least make an attempt to blend in w/ the jeep. it'd be a real pain to remove bumper/plate/winch from jeep , cut off the plate and grind out welds and redo....
thanks in advance
How about something like this?
I got those off of eBay for something like $50. I thought about rigging them to my turn signals, even though in my case my grill signals aren't obstructed.
i like it... i was trying to install the turns into the bent plate(winch bracket) to give the stockish appearance.. not to mention, avoiding tearing the lights off the front of my homemade bumper while plowing thru the woods...
Is there room behind the plate, behind the ones you have on there, so that you could embed some turn signals? I don't know of anything that would work, haven't looked.
I think these are the ones I purchased: eBay amber fogs
Go shopping at the next large interstate exit truck stop that you pass.
FULL of lights you can look at up close and personal.
Yeah, should have room behind there... which will require me to cut a symmetrical hole in the plate ..i 'd have to look at stock light hole rough opening requirement or whichever light ichoose...what will be the best method of cutting a 3-4" symmetrical hole in the 1/4" plate on each side of winch w/ backyard tools...could break out the torch but could get nasty depending on # of beers consumed.
no feasible availability of plasma cutter or other accurate cutting device.
