Converting fsj front 44 to 5 lug cj wheels
JERSEYJOE
JERSEY JOE
KEARNY
NJ
I would like to know exactly what I need to finish my Dana 44 front in my plow truck.
I have a narrowed housing I got from Crossbones years ago,
Using Dana 44 Jeep knuckes what else do I need:
Spindle?
hub and rotor?
Caliper bracker?
Caliper?
A set of small bearing spindles from a FSJ or Chevy D44 ('74 to '76), a set of hub/rotor assemblies from a Ford F150/full size Bronco (a lot of years but don't remember the range right now), Waggy/Cherokee/Chevy D44 caliper bracket and calipers (I used '78 Waggy ones).
This is something I copied and saved to notes for when I get to it
Thanks for all your guys help. I also checked with www.partsmikeparts.com. What I need to locate is a set of small bearing spindles from a 74-75 Jeep or 72-76.5 Chevy 1/2 ton. Then I need a Ford hub and rotor with bearing from a 76-86 Bronco. I still have those crappy automatic lockouts on my Waggy 44, so I need manual locking hubs too. Does anyone know a good source of those parts? Will I be missing washers, clips or anything else? Also, do I need a Ford outter knuckle or stub shaft? I want to still use the Jeep/Chevy calipers.
John N told me it was not worth it to go with used parts
Just buy new ones !
When I bought them for mine at AutoZone, they were about $32/each. That was for the complete hub/rotor assembly with studs pressed in. I took out the China bearing races and replaced them with Timkins. Probably a few $ more now, but still not worth using used ones.
