Emissions and all that goes with it.
Ol'Red
Twentynine Palms
Ca
After a buddy and me fighting with California on emissions for a while and not finding much in the way of answers when it comes to smog pumps, catalytic converters and emissions testing I figured it was time to start a thread on it. If we are having trouble someone else probably is too and likewise many of you on here have already solved the problem.
So to get this started... We both have 258's carb'd. One with a 2bbl and one with a 4lower cfm bbl. Mine has always been a ca jeep and had the smog pump on it already. But I've come to learn that it wasn't set up correctly because there is no vacuum solenoid and the pump just pushes air into the exhaust all the time--which makes for some nasty popping and backfiring when decelerating. When we look online there isn't much help. You can buy the air pump but there aren't any kits that include all the parts for the emissions system--solenoid etc. does the smog pump really do anything anyway if you have a new catalytic converter?
My buddy's 82 is considered a "gross polluter". It has been an easy coast scram all it's life until now. No smog pump but has a newer cat as well. We just replaced the fuel filter and air filter because the little things can really clean up emissions sometimes, but is there something we are missing?
These are my questions but at the end of the day I'm hoping this thread helps anyone in any state with emissions stuff.
This site has a bunch of useful information:thumbsup:
http://dale02.home.sprynet.com/list.htm
I had to read through this a few times until all the under hood junk started making sense:rotfl: But, I used the information from this site, and a FSM, when I did a bunch of work under the hood of my green 83 Scrambler. That particular Scrambler has the feedback Carter carb, but previous owner's had disconnected most of the required feed back sensors and doo-dah's. I spent a few nights going through all the under hood stuff on mine, and it now runs much better. I still have not hooked up the EGR system or the "pulse air" system, but those two items are purely for emissions, and MS does not check fot that stuff:thumbsup: I will probably, eventually, source the items I am missing and hook these two systems up, too:rolleyes:
My 83 runs "pulse air", which accomplishes the same thing as the smog pump - injects air into the exhaust, either upstream from the cat, or directly into the cat, to help clean up the emissions, based on what the O2 sensor tells the computer.
The pulse air is a series of valves that take air from the air cleaner and shoot it into the exhaust pipe via a set of hoses/tubes. IIRC, your smog pump is belt driven, and pushes air directly into the exhaust manifold. Besides the pump, there should probably be some other doo-dah's that you are missing - deceleration valve, one way valves, not sure:shrug:
The biggest problem - if you are missing items or if they are broke, it is hard/impossible to find some of this stuff:confused:
Awesome! I'll have to check out the site when I get home.
You nailed it with the last paragraph... Biggest problem is finding the parts hen they are missing or broken, and I have both.
Originally Posted by walkerhoundvm
^^Ditto^^. That's why Howell kits cost so much: they're the only legal alternative to resourcing antiquated smog parts in many states.
You can get rid of the air pump, but must keep the original intake and exhaust, as well as thermal vacuum switch for EGR and charcoal canister purging. Air cleaners may be aftermarket...at least in northern Colorado.
Yeah, I've looked at the Howell kits but I'm already running aftermarket intake and exhaust. Got the charcoal canister and its hooked up properly. No EGR or thermal vacuum switch though. Researching Texas requirements now.
Posted from the new "what did you do..." Thread.
How long til your move to Texas? Exhaust manifolds can be had aftermarket for pretty cheap, and used intake manifolds are available on a daily basis on eBay for less than $100 shipped.
Without those, I wouldn't even bother with the Howell because you won't pass with aftermarket manifolds no matter what you do :(
Great info on the intakes etc. I didn't know that you had to have stock intake and exhaust with the Howell kit... I was gonna just put on an adapter plate to mount the TBI to my aftermarket manifold. Glad I didn't do that now.
As far as moving back to TX... Not nearly as soon as I would like. It's my home of record so I have all my vehicles registered there. Won't be able to move back to tx any time soon unless somehow I get stationed back in college station at the A&M. 👍
The OEM manifold deal is only in emissions strict areas - California, Metro Colorado, some others.
I did what you were wanting to do - I had aftermarket manifolds and I put a TBI on it and passed the first year, only because the smog monkeys didn't know what they were doing.
Second year through, I failed the visual and had to spend 2 months and $1000 getting everything back to stock - then putting the Howell kit back on. And it still didn't pass, because the kit Howell sent had an improperly designed ported vacuum...or at least the wrong model throttle body. At that point I was sick of it and just dummied it to pass the visual and then undummied it to pass the tail pipe.
I live in East Texas where there is no smog or emissions test and I am in process of removing all the smog do-dads on my '81. I would normally leave everything stock, however the miles of vacuum lines drive me nuts. I had to redo my '91 Grand Wagoneer and swore I would never again. I guess I should avoid a move to Cali.:thumbsup:
I've pulled everything off for now... Debating about whether to mess with the MPFI or not. A lot of money and I'm not sure the gains are worth the cost. Could buy a whole new engine for the cost of an MPFI.
On another note, what part of east tx are you from? I grew up on Lake Fork.
I grew up in Tyler, lived in DFW for 15 years but couldn't stand the concrete and lack of pine trees. We moved back two years ago and love it. My plan for now is to remove all the smog and rebuild the Carter, I bought the Scrambler two weeks ago it had been sitting for five years. Lots of new fuel lines etc. etc.
Wow. Small world. My folks still live just outside Mineola.
Congrats on the scrambler.
Back on emissions, we opened my buddies 8 and quickly realized he didn't have any of the lines hooked up to his evac canister... He also found an exhaust leak. Hes got all the parts ordered and we should be getting it fixed here soon.
Mine will likely be a longer process.
Originally Posted by Ol'Red
Been looking at them but man are they pricey. Does the mpg and hp really increase enough to make it worth the $$? If anyone has one they aren't gonna use and want to sell feel free to hit me up...
I lucked out and bought my MPI kit from a guy who bought it new, then never installed due to an engine swap. The kit is pricey, BUT, all the parts are brand new from Mopar, a complete wiring harness that is plug and play (3 wires to hook up to jeep, that's it) and it uses stock 94 YJ 4.0 parts. The instructions are great, and Hesco has great customer service/product support.
IMO, the HP/mileage increases are worth the cost over a TBI setup:twocents: You can probably pull a 4.0 out of a junkyard, swap it in, and figure out all the wiring yourself for cheaper. BUT, you will be using used components, it will take a lot more time to swap in a motor/figure out the wiring then installing the Mopar MPI kit. And, depending on where you are, the junkyard swap will be more difficult to smog.
If you have moderate abilities, you can swap the Mopar kit on in one long Saturday. The Mopar kit also has the OBD port, so you can scan the system as if it was a stock YJ. All the stock trouble codes/engine parameters will be displayed.
I have drove my red Scrambler, that has the Mopar MPI, form Biloxi, MS to Utah, Michigan, Missouri, kentucky and all over Alabama/Louisiana/Mississippi. It has never left me stranded, gets consistent 17-18mpg at 75 mph, and handles altitude changes no problem. I guess I am biased:thumbsup:
