Flashover604's incomplete build and non-restoration
I had some made locally and i had mine welded to the frame. They don't go any lower than the frame so i have the same clearance. Mine match my Runck bumpers but the guy who made them make any style. I just told him what I wanted. Was well under the cost of buying pre made too.
I have a glass tub as well.
Dain
You don't happen to have any pictures do you? I may grab some cardboard and start mocking up something and try to get a quote.
Let me take some specific ones. But here is a reference for the look i was going for.
Dain
Ok. Here are closer pics.
Not a great pic of the cross bar but ....
And here is the Runck bumper I was matching.
Dain
One step forward, and slightly to the right.
I found a fold and tumble rear seat on CL. The guy said he had it in an FJ40 before putting troop seats in. Dirty, with the stitching coming undone along one seam. Perfect. That means cheap... I'm putting seat covers on anyway. Not the best part of town for cash transactions but that's ok. I texted the address to a buddy and told him to call the cops if I didn't text back in fifteen minutes. Thirteen minutes later I'm on the road. The previous owner of my scrambler was nice enough to leave the mounting brackets in the floor, so the seat slid right in. Unfortunately they mounted the brackets too far to the passenger side so only one side of the latch caught in the back. Oh well, the brackets are only bolted through an eighth inch of Fiberglas anyway, so they'll be coming out shortly when I reinforce the bed. I'm a little conflicted on my color scheme... The PO put grey Bestop front seats in the jeep. I bought a brown with tinted windows Specialty Top Co top earlier. I was going to get a set of brown seat covers with the black sides, but I think I may just do all black... Who knows. Lining up supplies to do the frame repairs, then brakes, then tie rods/ball joints.
I still have a miss at idle. The mechanic at work said it sounded like plugs or wires. I have new wires, but got the wrong plugs. The hex head was too big and I couldn't get a socket to fit inside the recess of the head, so I'm hoping that new plugs will help, although to be honest, short of a two stroke motorcycle I've never noticed one bit of difference with new plugs...
Hey dain, I like the look of the rocker guards. That runck bumper is what I think I'm going to try my hand at reproducing, you know, the spirit of!
My front is a "Runck in sprit" as well. Not nearly as heavy as the rear bumper (real Runck). Go for it. I thought about round tube sliders that wrapped around the body a bit and had a built in step but decided to go simple and match the square tubes to the bumpers to complete the look. And I am very happy. Keeping it pretty period correct.
Make sure that you have those big metal washers or a metal bar for the seat and belts to bolt through in the back so that the seat does not pull through the fiberglass tub. Mine had some, but they were not big enough in my opinion. I thought about welding a bar across the frame to bolt the seat belts through. But have not yet and no one really uses my back seat anymore anyway. I am thinking about pulling it out and running a half cab in the winter.
Dain
Here's my plan... The Fiberglas bed looks like Someone put something pretty heavy in it. Makes Humpty Dumpty look fabulous post-fall. I think I'm going to throw a quick (read: ugly) patch on the busted Fiberglas then take a piece of 3/16th or 1/4" aluminum and lay it on top of the Fiberglas bed. This will bolt to the frame via the body mount bolts. When I put the seat and belts back in I'm going to run either bar stock or angle iron under the Fiberglas. This should spread out the load. It'll have to pull through steel, Fiberglas, then aluminum instead of just Fiberglas. The bed already just looks flat. It doesn't have the ribs like a regular scrambler, so I'm not worried about it looking different.
Well, I did it again. Hit the PayPal button and watched 10% of my budget DISSAPEAR into the ether in exchange for some US steel, this time in the shape of a set of rocker guards. I ended up going with the Poison Spyder Ricochet Rockers. I've had my eye on them since before I had the jeep and every time I looked at something else I came back to them. 4wd Hardware is getting them to me with free shipping, so even though I have to pay Ohio tax they're still cheaper than anyone I could find. Believe me, I LOOKED! I'll spend four hours plus looking online to save a ten dollar handling fee...
Now I just need to get all my stuff rounded up, get the jeep to my buddy's place and lift the body off so we can start cutting, replacing and strengthening.
When Chiefwaho gets back I've got an order to place.
Remember this?
Well, I know some of you folks have seen people talk about ChiefWaho's plates and cross members and thought to yourself "Ehh, it'd be NICE to have 'em, but I just don't know if they're worth the money". Hey, I'm with ya'. Two sets of frame plates, a couple cross members, that's some SERIOUS jack that got sent to Kansas for some steel that no one will probably ever see.
HOLE. LEE. COW.
http://
Those are the frame plates on the left. Those bad rascals are LONG! I had no idea that they were so big (twss). They will EASILY cover the spots that I need to cut out and patch.
http://
The cross members are on the right and promise to be just as nice.
I'm currently spraying every bolt that MIGHT need to come out, off, or apart with PB'laster in preparation for pulling the body off next week, sanding, de-scaling, cutting, welding, re-enforcing, painting, and putting it all back together.
Consider this the teaser...
Good choice on the PSC rockers. I have the rockers and rear swingout on my LJ. I also had their steel fenders on the '07 Rubicon JK I had and laid it over and they only had a scratch on them. Great products.
I can't wait to get my paws on them. They're supposed to be in early next week. Unfortunately I'll have my hands completely full with the frame repair and I'll be lucky if they get installed, but I'm definitely looking forward to that part.
Chief's plates are excellent. I used his rear crossmember, talk about serious beef. I wish I'd installed the frame plates when I had a bare frame, but my frame was minty.
Good call on the rockers. I'm having some 3/16" bent next week for my rockers, then I have to drill, cut, fit and powdercoat. The initial $62.00 for steel was all the temptation I needed, but something tells me I'll be over $200 when done.
Just a little progress...
Let me start by saying that I don't know if the Mister Clean Magic Eraser is actually powered by genuine Eye of Newt and Dragon Spit, but these little suckers are awesome.
I pulled one out and went to town on the rust on my Fiberglas under the ratty steel rust dripping door. It got rid of probably 80-90% of the rust. It got rid of the blue paint scuffs on the tailgate. It got rid of the black paint marks on the hood where it had flopped up against the soft top windshield channel. It removed the black marks, grease marks, oily finger marks, tool marks, everything but Marky Marks off of the tops of the front fenders... It slices, dice, repels mices.
Seriously, darn things work. I also think they remove paint. The runoff water was milky white. My jeep is milky white. I don't think this is a coincidence. I'm fine with that. I didn't go crazy with them, but they got rid of a bunch of nasty looking crap.
Tomorrow I head to my buddy's house to make room in his shop to de-tub my Scrambler in preparation for the ChiefWaho-ization of the frame. This is gonna be hectic.
I was just listening to Marky Mark's Good Vibrations yesterday! My wife was making a new ringtone.
And yes, the Magic Erasers are like a fine sandpaper. Glad it worked for you. Sounds like it is coming along!
Dain
update.
I'm a little disappointed. My buddy and I got the body off the frame. I found a lot more rot than I expected. I took a wire wheel to the frame and located several more spots where the metal was just there for looks. The passengers side is pretty solid except for a six inch long rusted seam, but the drivers side is a complete wreck. the Chiefwaho frame plates will help, but im going to need to fix a bunch of holes. Out of curiosity, where is the CJ8 frame different from a CJ7 frame? Are any parts interchangeable? I'm serious. I'm at that point... I need a new fuel tank sending unit, fuel tank strap, bourbon, heater hoses, bourbon, I think my battery is shot, the body bolts and mounting pucks are shot, I need a shot, my transfer case output shaft to the front driveshaft has some play that MAY be fixable, the front driveshaft has a ton of play in the slip joint, I found a strange "patch" of some kind in the freeze plug at the back of the engine, good lord, what else was there...
Where's that bourbon?
it was a bad night...
Update to the previous update. No bourbon was harmed in the making of this post.
On the bright side, I now have full working knowledge of how a plasma cutter works. (WELL). On the down side, I learned by cutting the frame off of my scrambler. Ok, not the WHOLE frame, but the last 20" is gone. It was what I'd refer to as "steel lace". Might be alright for Victoria's Dirty Secret, but not the rear end of my Jeep. In its place is a nice, stout, non-rusty length of 2"x2" 1/4" square tubing. The crossmembers have been test fit, the ChiefWaho frame plates will fit perfectly (like there was ever any doubt) and cover our repairs. I've got a new fuel sending unit, fuel line, fuel tank strap, twin-stick kit, and a bunch of other stuff hurtling its way through the interweb towards my part of the world. Hope everything goes back together....
Sixty inch lift kit almost done...http://
Shameless shot of my favorite Double H cowboy work boots... With a view of my custom "vented" frame...
http://
This isn't bad, right?
http://
My good buddy Jared, doing what Jared does well...
http://
You know, there really isn't too much to these little buggers, is there...
http://
Uh oh! What's this? A box at the door. Christmas in August. Tank sending unit, tank strap, e-brake cables... Then my buddy calls. "The UPS guy is pissed..." that's great news! That can only mean ONE thing...http://
http://
He said the quality looks phenomenal.
In his words, there's more steel here than my frame. That hurt a little. Any one have any ideas for painting these things so they stay somewhat decent for several years?
So, the only thing I'm waiting to have delivered is the twin stick setup from JB fabrication and the new clutch linkage setup. I can do both of those things with the body back on, but they'll be MUCH easier with the body off.
Giddy up...
