Jims "repair"-ation thread
When you replaced the doubled up wires on the starter solenoid, did you use fusible link wire? I found mine melted in the same area also and it originally had fusible link wire. I replaced mine with fusible link wire soldered into the harness and crimped both wires into one shrink ring terminal. Just a thought.
I really like how everything is turning out on the eagle. I would love see how that interior would look with some low back tan denim levis seats from a 1979 eagle or (IIRC) some high back tan Laredo seats from an 1980 eagle. I absolutely love everything none-the-less. Great work!
To tell you the truth, I didn't know there was such a thing, I do know that the old wire was crimped and soldered where I made my connection
I definitely would love to have a nice set of low back denim seats, but those are harder to find than any other seats I've come across
How about one front bench seat done in denim and two rear original rear seats, seat seven
I think my fusible link failed from use over the past 30 years, but I believe they are meant to melt or self destruct from too much amperage draw, much like a fuse or circuit breaker. I have not had a problem with my electrical system since replacing the link. Hopefully, it will save me from an electrical fire in the future. I purchased 2 feet from a local electrical rebuilder in the gauge I needed. My local NAPA only had it in longer rolls on the shelf, not by the foot.
As for the tan denim seats, that would be awesome. Re-do an old CJ-10a front bench in NOS tan denim and use levis buttons.:thumbsup:
Lookin good Jim. I might have to stop by this week before I leave for vacation.
Luke
I agree. My stomach just flipped as soon as I saw that picture...
OMG OMG OMG OMG OMG, put down a ton of painters tape over that area and then mark, punch, small drill bit, bigger, bigger, unibit and then you are set... eliminates a lot of the chances of scratches to the paint... if that walked... oh yeah, you said you were nauseous...
Last weekend I had to pull the Trans/transfer case and replace the clutch fork !
Trans jack comes in handy !!
Should have wired the radio up while I was there
Installed stock exhaust while crossmember was out
Last night I installed the borgeson steering shaft
Drilled a pocket for the allen to fit in to
