Jims "repair"-ation thread
Pretty lucky !!
Carb has been sitting since I started this project
But , it did take me two days to get it started
Long story short, The needle valve for the float is in the fitting on the front of the carburetor where the gas line connects and tarnish had it stuck,
I thought I was having problems getting fuel from the tank, all along I just wasn't getting gas to the carb bowl
Things I've done in the last three weeks
Started with installing could hood kit (aftermarket) to get motivated
Next I replaced the coil wire that was melted in the wiring harness ,mounted to firewall
Before pic
Had to replace more burnt wires wires at ignition relay
I crimp connected and then soldered those connections
Before pic
Cleaned And painted fender supports and battery tray
Replaced battery cables and cable to starter
Mounted washer bottle
Installed borgeson steering shaft (acquired)
(Still have to remove and Dremel indentions for Allen's)
Installed used master cylinder from parts Jeep
Need to flush all old fluid, fluid looks like crap
Repaired wire harness for taillights, had to remove trailer wiring that it was spliced in poorly
Installed harness and rear taillights(used)
Installed radio, speakers are on order
Installed seatbelts
Found a set that stand up on their own
Rollbar is from the 83 I purchased for the tub, so I switched from lapbelt's to shoulder belts
More later,
