Speaker Enclosures
How about building the box out of MDF, and using aluminum for the bottom - very easy to bend, keeps the height and weight down as a bonus
For the curves, a couple sheets of thin pressboard glued together will work just fine. Install the first one glued around the perimeter to the MDF sides. This is when the air nailer is your friend. For the second layer, put a full coat of glue (I use the yellowish wood glue, Titebond is one brand) on the first piece, then install the second piece. Nail every couple inches around the perimeter, or closer if it's a tight bend. Just like making a big curved sandwich. Once cured it will be strong and stiff. If vibrations are still a worry, add a piece of Dynamat to the curved part.
I want a set of beer speakers boxes. Do they make one in Miller Lite? Bud gives me a headache, even if I only have a couple.
Alright, let's allow a little latitude for creative license!
Enough said, I went to Lowe's this morning and dropped $25 on supplies, time to let 'er rip!!
2 sheets of mdf (looks like one would have been enough), some 1/8" melamine for the curve, and wood glue.
I hope I have all my fingers when I am done.
The problem with most of these boxes are that the speakers either aim across facing each other or up. You lose alot of sound with them like that. also, if you have rear passengers and are going down the road, you have to blast them out so the driver can hear. i will take a pic of what I built. They are angled towards the driver and passenger and it sits on top of the wheel well and hold 6x9s.
karl
karl
Karl, I hear ya and look forward to your solution but here's where I'm at...
- my kids are at the age where they no longer want to be around us, not because we are mean but because we aren't cool...
- I would never expect an adult to ride in the back seat and be surprised that it was not an enjoyable experience... get your own Jeep!
- hopefully the amp and subwoofer compensate for "most" of the lost sound.
- for the most part, our Jeepin' world s a two person affair, me driving with my wife or me running errands with the child that drew the short straw.
The back cargo area is for coolers and beach chairs, not people!
End product, all fingers accounted for.
Bud-template (aka budplate) sacrificed for project
Finished enclosures, minus holes cut for speakers, melamine on the curve, and connection terminals...
The speaker boxes fit quite well and are snug with little to no wiggle room. I test fit the melamine with a heat gun to facilitate bending around the wheel well curve, it worked like a charm. Unfortunately I have run out of time and am headed off tomorrow, the balance of this project will have to wait until Christmas. All in all I am happy, last time I tried anything like this I was in high school and that was almost 30 years ago. YIKES! :smokin:
They look REALLY good. Nice work. For the curved part, will (did) you cut the correct width but leave the panels long - then trim once stapled/glued?
Thanks, and yes that is the plan. I did a test fit with a heat gun and that made the material malleable enough to fit the contour. I will seal it with a silicone (as well as all the inside seams) and tack it with a brad nailer when closing it up. The photos are a bit deceiving but it sits in there pretty nice, follows the contour perfectly. I will post up in Christmas when I get it finished. I'd be happy to send the budplate along to anybody who can scan it as a proper template.
I'd be interested in seeing what you have!
karl
Liquid nails works better than silicone. Looks good so far. You might want to stick s layer of Dynamat or similar on the melamine to eliminate unwanted vibrations.
Im sorry. I forgot. I will have the Jeep out tomorrow and get you some pics.
Karl
Ok here are the speakers I built. They hold 6x9s and are about even with the top of the bed.
Karl
I like those Karl.
Gueon, got any finished pics?
Two good options here for when (if) I get around to putting the ACME top on the Scrambler.
Karl, where did you get your carpet?
Unfortunately no, it sits in the same unfinished condition... the weather was far too nice this summer to spend it in the garage working on speaker enclosures! I hope to get them done when I get back for my treatments in September, I'll have 7 weekends to wrap this and other projects up! That said, I am liking Karl's solution better than mine.
