- Wilbur by the Sea
- FL
Thanks,
Here's the letters almost done. Still need to wet sand them down a tad. You can't tell in the pics but the edges are rough where the vinyl peels away and cuts the paint. . A wet sand with 400 then 600 will smooth out the edges. I just have to paint the copper stripe up top between the yellow/orange and then I van clear the whole hood.
IMG]
She's got color! ..and two coats of clear. Next is to let it dry until this evening and then sand it all down with 400 grit wet dry. Then lay up the stripes, spray those and clear the whole shabang again. If I had a spray booth (controlled environment) I would have laid the stripes on top of the base copper and then cleared the whole thing once. In the end the result will be the same but with more depth.
