33's with 2.5" lift or 4"
jims chop shop
stafford
va
I'm taking this down from spring over to spring under
I plan to use the 33 inch tires that you see
2.5" springs or 4" springs
Anyone want to post a pic of your rig with either /or
Sent from my iPhone
I have both a 2-2.5" and a 4" on my two CJ-8's, and they both run 33" tires. The '81 has the shorter lift and narrower 33's at 9.50 wide, while the '83 has 12.50 wide tires. It is my opinion that the wider stock axle on the '83 combined with a 12.50 tire might rub with only the 2.5" lift. Interestingly, the 12.50 wide tires look like a natural fit under the wheel wells in the narrow axle '81, while the 9.50 flush out nicely on the wider axle '83. However, I use the '81 a lot more often, so I keep the 33x9.50 tires on it.
I doubt this information helped you much, since I don't have pictures and it reads as though you are trying to achieve an appearance, as compared to my information regarding potential feasibility issues.
Sent from my iPhone
4" springs on both jeeps with 33's. Hope this helps.:thumbsup:
Depends on the brand lift/how you use the Jeep:shrug:
Red Scrambler - 4.5" RE with 33x12.50, rub slightly while off-road (and it has a 1" BL)
Tan Scrambler - 4" Skyjacker with 33x12.50, no rub, springs are stiff (no BL)
Both Jeeps are used off-road:twocents:
A stiff 2.5" might work, until you hit the rough stuff:shrug:
I got 2.5in skyjacker and 0.5in shackles with 33x12.5x15 with 15x8 wheels. I don't take it offroad but it looks good and does not rub or even come close on the road or driving through the uneven yard.
Onesourcemike has a couple of pretty clean-looking Scrambler Jeep models in Wilmington, and LetchcoreCJ7 has a nice CJ-8 model in Nashville...technically.
Thank you for asking this! I did a 4" and 33s on my CJ7 and it looked great for what I was going for. I was wondering if I would like the same setup on the 8 or if it would look small (like my LJ does on 33s as compared to my past TJs on 33s).
onesourcemike - those pics sealed the deal for me. 4" and 33s will work just fine. :thumbsup:
These are 33 inch tires that actually measure 32 (go figure). I have a 2 1/2" spring lift with an extra inch lift via shackles. No body lift.
What the #%^* is this above ? What happened to the picture. Chew it up and spit it back out ? The happy painter guy from public television???
Yeah, sorry that my camera sucks. I looked for a picture of my junk and this is the most current picture I could find. It was in the background of something else I was photographing, and I cleared it up as best as my computer would allow it. My other picture is from the late '80's, but doesn't have the suspension and tires that are relevant for this thread.
So, how did you get that screen shot with Imageshack and my name on it? Your comment about the afro-headed painter guy on PBS made me laugh!! :)
Try to imagine that you are a tree. How do you want to look out here?
Sent from my SPH-L900
Do you not have a cell phone made after 2000??? They all come with decent cameras.
I've eaten potatoes that take better pictures than that.
