Purchased stainless steel 25 gal fuel tank.
jammer1
Maple Hts.
Oh
I purchased the stainless steel tank listed on ebay. Looks like it was built well but I just have a question on the sending unit/pick-up tube. Have any one ever seen one put together like this. They extended the pick-up with rubber fuel line, a piece of copper line. The filter is actually laying on the bottom of the tank. Also they extended the float arm by what looks like two arms put together and the float is also resting on the floor of the tank. I know I want to shorten the copper tube so the filter is off the floor and I need to tighten the float arms (you can turn the float, so I know it will rotate after awhile). I'll also raise the float so it's off the bottom. I just don't know if I'll have any problems with the gauge being correct and If anyone's ever seen this set up before. If this is in the wrong place please move, didn't see anything for fuel and it might only be a reply or two. Thanks.P1000722.jpgP1000724.jpgP1000725.jpgP1000726.jpgP1000727.jpgP1000731.jpg I know you guys like the pics, so here's a bunchhttps://www.cj-8.com/forum/images/smilies/wave.gif Sorry on the alternator pics, I tried to separate but it didn't work
I purchased the stainless steel tank listed on ebay. Looks like it was built well but I just have a question on the sending unit/pick-up tube. Have any one ever seen one put together like this. They extended the pick-up with rubber fuel line, a piece of copper line. The filter is actually laying on the bottom of the tank. Also they extended the float arm by what looks like two arms put together and the float is also resting on the floor of the tank. I know I want to shorten the copper tube so the filter is off the floor and I need to tighten the float arms (you can turn the float, so I know it will rotate after awhile). I'll also raise the float so it's off the bottom. I just don't know if I'll have any problems with the gauge being correct and If anyone's ever seen this set up before. If this is in the wrong place please move, didn't see anything for fuel and it might only be a reply or two. Thanks.View attachment 40541View attachment 40542View attachment 40543View attachment 40544View attachment 40545View attachment 40546 I know you guys like the pics, so here's a bunchhttps://www.cj-8.com/forum/images/smilies/wave.gif Sorry on the alternator pics, I tried to separate but it didn't work[/QUO
O wow was that the one I post up last week?
Sent from my SPH-L900
Yes, that's the one. Thanks, hopefully it will fit.
The previous owner didn't know who makes it. That's one of the things I'm hoping to find out.
Nice tread, were you able to finish the pump install. Did you use a 15 gal sending unit and put a extension on it?
It's been in use since the pics were taken. I chose an aftermarket sending unit and adjusted it to the tank itself.
Sent from my SCH-I545
