Ford 9"
This shows what mine weighs on race car scales, specs below.......
Shows the variation between weights. Considering the bit bigger tires, Dana 44 up front, hard doors, winch, AMC 360, and the other bits you have I feel pretty confident I get my build 400lbs lighter to accommodate the 2weeks of payload. Yours is amazingly well balanced front to rear. Of course I am guessing that is without a rear payload yet. I am pretty sure I'll end up with more rear weight than front since a lot of the weight reduction happens up front and middle then payload is mostly in back...
Those your scales or did you borrow them? Thinking I should get a set but they are pretty expensive.
I borrowed them from a race car guy.
Weight loss, want to keep the Jeep as light as possible. Allows for more payload without exceeding the GVWR by much.
FWIW, most of the ideas being tossed around here will totally invalidate the factory GVWR.
Example: A Dana 60 weighs more than a stock axle, but will also carry a heck of a lot more load... a net increase in payload capacity.
Not according to nameplate or legally. There is a lot more related to GVWR than just axles. Frame, wheel base, suspension/center of gravity, brakes, etc. Insurance may not cover you for operating a vehicle well outside of design limits. Read the fine print. Not a problem unless you cause an accident with someone. Besides there are numerous other advantages to having a lighter vehicle. Better handling, better floatation/less getting stuck in soft stuff, better fuel economy, etc. There is a lot of motivation behind my goal of having a decently built rig operating at the gVWR when loaded for 2 weeks bush...
Not saying there is not value to a lighter vehicle (as you noted, the list of virtues is long). BTW, being within factory GVWR does not guarantee you won't have a legal battle on your hand in you cause a serious accident in a modified vehicle. Even a non stock tire size is grounds for a court battle in our overly litigious society (there's a lawyer in hot pursuit behind every ambulance).
:cheers:
Legal battle isn't a problem as long as insurance supports you. My insurance agent wasn't concerned about the lift or tire size I have. He just didn't want a vehicle over the GVWR. All on a recorded conversation...
Insurance will only cover you to the limits of your policy. If damages go beyond that, the lawyers will come after you for whatever they can get/garnish... Ask me how I know.
Yep umbrella policy helps out when things go real bad when those limits are surpassed also.
Sent from my SPH-L900
