Who's got two thumbs and a winch?
Soooo, because I had nothing better to do, I started tearing this thing down for clean up and rebuild today. Since it's not on the jeep and not really necessary, I am kind of taking my time with it and doing some little extras to make it spiff up nicely.
Pulled off the power box cover and this is what I found:
I managed to break off a small stud and a large one from two different solenoids getting them disassembled. Nothing too crazy to tearing it down. Got it to this point:
Here's the Solenoids all off the mounting plate. My question at this point, are these specific to WARN or is a Solenoid a solenoid and I can pick up a couple of CJ ones to replace them?
The bolts for the motor were the first real hurdle of the project. They were stuck pretty good and being a slotted bolt, I was afraid of stripping it or breaking it off in the case.
This had been the handiest tool since I bought my Jeep. Not quite the power and torque of an impact wrench, but great for breaking stuff loose. Highly recommended. Popped both motor bolts with no problem.
The free spool knob was hard stuck and did not work. It was pretty crudded up. After complete disassembly, I tapped it with a sledge and then worked it with WD40 for about 15 minutes to clear out the sludge.
The brake/clutch mechanism was pretty stuck and required a puller to come off. I put a catch basin under it for the 21 ball bearings inside. Worked like a charm and managed to not lose a single one.
Don't lose these keys! One came came out with the clutch and one stayed on the shaft.
Top and bottom of the case. I cracked it open with a pipe wrench and it separated nicely. There was a lot of excess gasket material everywhere.
The insides look very filled with sludge. I think there was actual mud in the top case. The oil was very very brown
Here's the thrust washer and the seal for the main drum
And all the crap trapped between the case and the drum.
Build this first! super easy and will keep the winch from turning on you while wrenching. I just used some scrap 2x4 and a 6" trim board
I used Naval Jelly on the Drum. Here's a couple of pictures of the process. It's easy and strips the rust off while etching it for primer. let it sit for 5 to 10 minutes on the piece and then wash off with water.
Used this stuff as the base coat to prevent future rust, then black rustoleum primer, then VHT roll bar and chassis paint.
After pictures of the cleaned up aluminum
And here's pretty much where it's sitting now.
Ive got small parts soaking in Purple Power and the bottom case as well. Currently have 5 coats of base, primer and paint on the drum and the motor housing. I need to pick up aluminum paint, all stainless steel hardware and some electrical odds and ends before I begin reassembly.
So, fun story. I was rinsing out the bottom case from the Purple Power bath and a chunk of splined machined metal fell out. So, I stopped being lazy and pulled the last gear on the brake shaft and the large gear from the drum and at the bottom of the case were about 5 more pieces. I put them all together and used a zip tie to figure out what it was. Its the Cam off the pinion. If you look close you can see the breaks in the gear where it's actually in pieces.
Here's how it goes inside the case with matching gear
Apparently this little sucker is $130 and you can't just buy the cam, you have to buy the pinion with it. Probably one of the reasons this thing didn't work...
It's WARN part number 7732 if anyone knows a cheaper place to buy it than Amazon. I am also going to email WARN and see if they warrantee it. A free replacement would be nice.
Looking good. I hope to do something similar soon.
I've got an email in to a guy with an 8274 that says he thinks the motor is bad. Any ideas what a motor costs to have rebuilt or replaced? Nice Restoral by the way. I'm bookmarking it in case I get this one!
Every time I've called and dealt with Warn directly I've been very impressed with their customer service. Them and ARB have the best service even if you bought the parts used off Craigslist.
Check ebay for that gear (hartmansupergas parts out 8274's all the time) and summit has good prices on Warn stuff too. I was quoted $100ish to rebuild my old Prestolite motors off my 8274's. I opted just to buy good used ones from Hartmansupergas on ebay for $70-80.
Not sure about the chinese "new" motors on ebay for $75-100. I figured used OEM was better than chinese new.
You still got a bargain on that winch, even with the broken gear. I got one on a Waggy for $300, sold the waggy for $350, and still ended up with about $500 in the 8274. Had to buy lower seal kit, end cap, solenoids, wires, motor, winch plate, fairlead, cover, and one of my motor mounts broke off in the top housing, and when i was trying to get it out, the top housing broke in several places. New (used) top housing was another $75.
Yup. I am planning on about $5-600 into this after all is said and done. I talked to Warn rep today and he was very helpful. He's trying to find me just the cam right now. the Cam comes with the pinion and both together are about $130. I don't want to have to buy the pinion if mine is good. I've got a line on another cam if Warn falls through from a member here, which is pretty awesome!
Flashover604, if the price is right, I'd buy it with what he thinks is a "bad motor." It could be a solenoid or just the brushes on the motor. I've got mine completely torn apart at the moment and will try to post pics. Another issue I've read about in my research is bad grounds. What might seem like a big deal might not be.
Even with the broken gear, I don't regret this buy in the slightest as I can throw a hundred bucks at the project at a time and end up with an awesome winch for the Scrambler.
In other news, I bought fill and drain plugs for it yesterday. I'm going to drill and tap the top and bottom cases and install the plugs for easy oil change I am also going to paint the aluminum with silver Caliper Paint from VHT. It's supposed to have a 7 day cure time and then be bulletproof from there.
Here are the three main parts to the motor. There's a couple of things that could be wrong with a bad motor: The brushes could be broken or bad or just stuck, The spool could be bad, or a broken bolt. Most everything else is going to be a bad solenoid which is way cheaper than a new motor.
Apparently he's already replaced the motor with a Chinese one. It looks like something's missing here. I'm not an 8274 guru. He said he replaced the solenoids with bigger ones and the case won't close now. He's asking $125. What do you think? Pass?
Looking at the pic it seems like there are parts missing... It was on a trailer and has probably been used pretty hard, but they are pretty pricey. I'd just hate to get a screaming deal....then find out half the parts aren't there!
It's lying face down in the picture so the control box is on the bottom. Not sure why the control box is off kilter or why there are wires not hooked up coming out of it. You've got a motor of sorts and a drum, the cases appear to be good. There's a shifter pawl and some sort of brake on the left side of your picture. As long as the PO never cracked the cases, you've got a pretty good chance of having all the major parts. Does it run now?
He said it DID but doesn't now. He thinks the motor is bad. What do you think? Offer him a hundred bucks and see what I get? Aside from obvious damage, what do I want to look for on one of these?
He said that the "case" didn't fit due to the larger solenoids. What would bolt to the bumper/mounting plate? I guess I'm just not familiar with these enough to know what I'm looking at exactly. I've got a Ramsey REP 8000 with two good solenoids npbut a bad motor. I wonder if the solenoids would swap?
I'd go the hundred bucks route, knowing that you're taking on a project, but that's just me. I'd read through the two links I posted and learn some stuff about these winches. Worst case scenario, sell it for parts and you will at least break even on it.
The winch plate mount or bumper mount should be on the bottom side of the winch in the picture. The solenoids from the ramsey might work, but I would go with Warn solenoids, just for safety's sake.
Check the cable for frays, see if it has a remote control with it. Also a roller fairlead. See if there is a plate on the motor that says Warn or prestolite. Check the knob on the side and see if pulls.
That's the stuff I'd check.
