Soooo, because I had nothing better to do, I started tearing this thing down for clean up and rebuild today. Since it's not on the jeep and not really necessary, I am kind of taking my time with it and doing some little extras to make it spiff up nicely.
Pulled off the power box cover and this is what I found:
I managed to break off a small stud and a large one from two different solenoids getting them disassembled. Nothing too crazy to tearing it down. Got it to this point:
Here's the Solenoids all off the mounting plate. My question at this point, are these specific to WARN or is a Solenoid a solenoid and I can pick up a couple of CJ ones to replace them?
The bolts for the motor were the first real hurdle of the project. They were stuck pretty good and being a slotted bolt, I was afraid of stripping it or breaking it off in the case.
This had been the handiest tool since I bought my Jeep. Not quite the power and torque of an impact wrench, but great for breaking stuff loose. Highly recommended. Popped both motor bolts with no problem.
The free spool knob was hard stuck and did not work. It was pretty crudded up. After complete disassembly, I tapped it with a sledge and then worked it with WD40 for about 15 minutes to clear out the sludge.
The brake/clutch mechanism was pretty stuck and required a puller to come off. I put a catch basin under it for the 21 ball bearings inside. Worked like a charm and managed to not lose a single one.
Don't lose these keys! One came came out with the clutch and one stayed on the shaft.
