I think that's why the originals came with the auxiliary turn signal mounted up front next to the winch. That way the winch wouldn't block the signals. ICBW
My other one (also a warm, but newer. Was bought an Amazon a couple years ago) is centered. This was a used plate I bought here from a member (don't recall exactly whom it was).
Fit down perfectly on the frame mounted rails, but something doesn't look right......
I've seen a couple of different style mounting plates. I believe the newer one centers the winch in front of the grill and the fairlead is off-center. The older one (with the stamped "W") centers the fairlead and the winch is off-center.
Yeah...on those clevis mounts....the drivers side is off. Thanks for pointing out my shoddy work regular guy!
The roller is centered, but the winch is literally almost hitting the turn signal and the freespool knob actually sticks out a little in front of the passenger side headlight. You can see the W lines right up with the middle grill cutout.
I was wondering if this might have been for a different vehicle or something.
I think so. Look at your plate, there is no room to mount the aux turn signals. Now look at the plate in the link you posted. See the difference? The vertical portion of your plate extends the whole length of the mount whereas the correct CJ plate does not.
