What did you do with your Scrambler today? November 2014 Version
I haven't posted anything in a long time, been busy with yard work:shrug:
Changed the "new" master cylinder on this one, the lid had been leaking since I installed it.
Drove it to Mobile, AL, on Saturday, to a flea market:thumbsup:
Drove it to New Orleans, LA, on Sunday, to watch the Saints lose:banghead:
Besides a leaky pinion oil seal on the rear axle (the only seal behind the engine I didn't change:crazy:), it drove fine all weekend. MPG at 80 mph sucks, though, about 13:shrug:
Ordered a bunch of parts from CJ-Jim including a Centech wiring harness. Pretty excited to get this thing started
Rented a silver scrambler looking jeep in Hawaii and found a Californian friend to wheel with at the beach. 👍👍👍
Lol 👅okok not so scrambler looking but they ride so nice.. And what's with the window switches in the middle of the dash!!
This is a little closer to Scrambler looking, but I'm sure JJ still does not approve:
Added a grounding block this morning. Helped clean up the grounds for the aftermarket gauges and radio.
Later i will be adding an in-line coolant temp sensor. Just got the needed adaptor.
How's your new radiator ?
So far so good. Today I installed the in-line temp sending unit. After hooking it up the gauge still spikes full hot as soon as I turn the key to on. Maybe the gauge is toasted. I don't like that the flex-a-lite did not have a ground. I hope I am grounding it well enough.
Got the C-6 and NP205 shifters installed and linkages all connected.
Got the full doors and soft top on for the winter, with my helper!!
Got the bulkhead out yesterday which was glued in and working towards treating some rust under it and the rollbar on the 1985 SR.
"Dipping" wheels. Trying out the Plasti-dip.
From here...
To here.
Got the rollbar out and the rusty underside ground down and ready for paint
I annoyed the guys at the airport and got them to swap tires for me. Decided I had to put the new 35's intended for the white jeep on the tan jeep, and put the 33's from the tan one on the Wagoneer rims for the white Scrambler. Threw three wheel weights on the way home... darn aluminum rims anyhow. The steel rims I bought last year wouldn't fit over the Waggy front calipers, and the 35's rubbed the springs big time on the stock Waggy rims, so time for a swap.
Helped the gearing a little and every inch helps not dragging in the snow. Maybe a little more arch in the springs next...
