What did you do with your Scrambler today? March 2015 Verson
jammer1
Maple Hts.
Oh
Pulled the fuel tank of the cj7 (I know it's not the cj8). Going to install a 21 Gal. Poly fuel tank. Just haven't decided on how to handle the extensions for the skid plate. I was going to weld metal to reinforce the joint between the extension and the skid plate. The extensions look like a treated metal that may not weld good. Tomorrow I'll probably try a bead to see if it's good.P1090700.jpg
Picked up the head from the machine shop today. Painted it blue and painted the intake cast aluminum. Now I just need the rest of the parts to show up so I can finish up the motor.
not a darn thing... way to much life interferring with living... i did manage a coat of paint on the winch mount yesterday though...
Busy day. Timing was way off. All new wires to the starter. Adjusted the carb, cleaned the K&N, New battery cables, compression check, 150/150/120/120/150/150. Satisfied with that. Adjusted the idle. steamed the motor and underbelly. Letting it drip tonight and I will start tackling leaks tomorrow.
Finally got my side steps on so my kids can get in the jeep.
pulled out the passengers seat and built a mounyt for my ARB freezer/fridge for two weeks jeeping and camping in Utah, Nevada and California atthe end of the month
Interior cleanup day. Pulled all of the carpeting insulation and seats. Pretty smart, the PO had placed in ground pool insulation under the carpet kit to help jeep it warmer when he was hunting in it. It did harbor some moisture, so as you can guess there was some rust underneath. nothing through the floor but bad enough I will address it. It's amazing how long it takes to scrape and scrub out 30 years of dust and dirt. Half done. Cleaning the inside will be a whole weekend project!
Not today but last thing last weekend I gave all the rot a coat of rust converter. Will be some time before the OL comes back to town for the big teardown so I'm in maintenance or arresting mode with it. Haven't dug it out of the shed just yet, got here an hour ago and had a power nap on the deckImageUploadedByTapatalk1425714025.833327.jpg. Better got off my hiney and go see how it looks.
Ok so treated rust looks ok and the boys wanted to go to the dunes. Who am I to say no?
Found a retired welder that hopefully willing to plug all of the holes in the tub. (Insert dancing banana here)
So cleaning 25 years of dirt and grime out of the interior I'd done. Minor rust under the old carpet. Gonna treat that and move on with life.
imagizer.
Went to the salvage yard looking for a 4.0L fuel pressure regulator vacuum line. Not only did I find a great condition line, I also found a MC2100 1.08 for mhinchliffe and this....Radio cost me $30 ($25 for the radio and $5 if I wanted to cut the harness for the other end of the connectors).
Great score! What did it come out of?
Did not get the year, but it was definitely a late 70's Waggy. Not really sure what I am going to do with it. I just finished modifying a radio delete panel to hold my ARB switches.
Did you get any pics of it? Might be some other good FSJ parts on there that you could pull and make some money on.
I think it was 77-79 ish because of the face plate color , but only cause I have that same color in my 78. If you want to make some money on your purchase to increase your jeep parts find, put that baby on eBay it should fetch 200 min and more of you have the original mic and even more if you can bench test it :) :cheers:
I don't have the original mic, but planned on seeing if it will power. The rig was freshly delivered and drivable. Guy running the lot said the radio worked, but had no idea that it was also a CB.
I do not have any pics, but should be back next weekend. There is a local guy who collected a lot of FSJ stuff with his son over the years that is now selling. Here are a few:
http://www.ksl.com/auto/listing/1916710?ad_cid=3 Chief with WARN SE8247. Sticker is warn away, but still has the manual and receipt from dealer install
http://www.ksl.com/auto/listing/1916746?ad_cid=11 J10 Stepside
http://www.ksl.com/auto/listing/1916732?ad_cid=12 77 Waggy with 401
http://www.ksl.com/index.php?nid=231&userid=692805 Odds and ends
