What did you do with your Scrambler today? March 2015 Verson
I was able to land a deal for the Scrambler's front axle... I had the D44 one already, but now I have front and rear and the pump!
pulled out the passengers seat and built a mounyt for my ARB freezer/fridge for two weeks jeeping and camping in Utah, Nevada and California atthe end of the month
Well, where are the pics? We'd like to see.
Had a minute so I started testing the radio/CB. Powers up. Did not have an antenna, but the FM would tune in a bit. Sound came. CB channel indicator works and channel selector works. High Hopes here. Need a mic. CB Works.jpg
It's been a wicked winter here and I haven't been in here for more than a month because the snow piled up so high couldn't get the doors open. but the postal has made it through the winter. From what I'm hearing about the mild winter in Alaska I'd say that this jeep brought winter with it :eek:
14 hour marathon session of of grinding cutting , hammering and welding patches the postal looks like quilt. But it had to done.
This morning I troubleshot my misbehaving ignition system. Thanks to wm69 for help with this!
Symptoms:
1) not shutting off when I turned the key off.
2) ability to start without the key in the ignition
3) difficulty turning key in cold temps - stiff ignition.
I picked up a new ignition switch, a new lock cylinder, and a new sector gear and rack. The other day I installed the ignition switch. It was a bit tricky until I took out a couple large bolts holding the steering wheel up, so I could lower it a little to reach the screw furthest from the firewall. It's kinda clamped under some things so it helped to have room to get a wrench in there and actually see what I was wrenching.
The new switch solved problem #1, not shutting off, but not the others, so I waited until the new cylinder and sector/rack came in yesterday.
This morning, I pulled apart the upper portion of the steering column using some great instructions I found by John Strenk. I got the old lock cylinder out, pulled the old sector gear out (which is cast, not plastic like the replacement), and cleaned it up using a toothbrush and soap. Sprayed a bit of WD-40 into the rack area, toothbrush again and then some paper towels to clean everything up. Fresh lithium grease on the old sector gear, and reinstalled it. That takes some trial and error if you weren't paying attention to how it came out. You've got to get it lined up right so when you install the cylinder everything works as it should. Took me a couple of tries. I ended up reusing my original sector gear and rack, and will be returning the ones I bought.
Installed the replacement lock cylinder and got it locked in, everything seems to work as it should now. Won't turn without a key, and seems to want to turn easier now.
One thing I found out was that I have an accessory spot on the switch, but nothing comes on. Is that just an old CJ thing, or did I install the ignition switch one space off? Turning the ignition on seems to hit all the right spots, but when I turn it back - which I couldn't do with the old lock cylinder, nothing comes on :confused:
One more problem solved, and another one pops up as usual!!
I got the postal out yesterday as planned. It's doing its best Alaska impression, which was the last time it touched snow before this I'd bet...
that is a very clean one, I remember when I saw them all line up the night of the the government auction there were some that looked liked then had never been used
Figured out the acc issue - it was because my radio wasn't plugged into the radio slot in the fuse box. Noticed the voltmeter shoot up when I went into acc this afternoon, figured it had to be sending power somewhere.
Thanks to the generous help from jammer1 and rustycrawler, both of my front turn signals work. Woot.
Goes to show you how few "accessories" these thing have. Ha!!
PS- read through your build thread the other day. Time to update that sucker!! :thumbsup:
Has been upper 60's in Utah so paint will dry. Got new bushings pressed in the 8274 yesterday, so I started painting all the small parts. Got it mounted this afternoon. Still need to wire and work on the signal lights. Winch Installed.jpg
