Getting broken off stainless steel bolt out of aluminum
wm69
Silver Member
God's Country
AR
Anyone have any luck with Alum or nitric acid?
Have to replace a part on my washing machine. Had 6 stainless steel (torx head no less!) bolts holding the rear support/spindle/spider arm on the back of the drum. The spider arm is no longer available (without paying $300+ for a whole new drum) so I need to get this one where I can use it.
Bought a replacement arm used from a guy parting one out, but three of the 6 bolts sheared off in the aluminum. He started to drill them out and I told him to hold off as I was worried he'd ruin the part.
I was going to try drilling them out but after looking into it a little more it looks like you can get a chemical bond between stainless and aluminum, and I'm not confident that I can hold a drill steady enough to avoid wallowing out a huge hole. Not confident in my local machine shop either. Chemical looks like it might be a good option, but most subjects I've found from google say "I've heard" or "supposedly".
Anyone have any luck doing this, or other suggestions on how to get these things out? The wife is screaming new washer or get it fixed now.
I spent some time fixing my old washer, in the end it wasn't worth the time, effort and parts....got a new one...works great.
Well I'm in the MAW stage. Bought new bearings, tore into it, needed the new spindle/spider arm, so bought that. Now I (hopefully) just need to get these old bolts out and will be able to bolt it back together.
If there is enough material you may be able to drill it out and helicoil it.
Don't actually have to use the stock M6 bolts. Think I'm going to take them to a local mechanic who is a hobbyist gunsmith on the side. He has a drill press and a small lathe.
The local machine shop does great welding on tractors, but precision work isn't his specialty.
I don't have a drill press and Dad's is buried deep in the old shop (no power there now) so I don't have any way to accurately drill it out without fear of wallowing the hole and/or drilling a crooked line.
The guy I''m thinking about probably can do it, but I'm not sure if he'll want to fool with it. Will probably depend on how busy he is in his shop. If I can get him to drill the old ones out I'll probably enlarge the three empty holes, tap them, and just use slightly larger bolts on all 6 mounting points.
Get some Dewalt titanium bits and just drill it out by hand....use a really small bit for the first pass then work your way up....it will come out....
could heat be your friend? Al has a much larger expansion coefficient than ss if i recall correctly, then geer the bolts out with a gentle hammer and punch or even needle nose pliers?
just a thought
