Time for the LS transplant.
With a 4L60E, Atlas, 1-tons, 4-linked front and rear with air shocks, full cage..................
That sucks, having to redo the valve seats would have been nicer.
Yep, valve seats would have been super
Oh well, the engine always was a crap shoot. I had no idea on miles or compression, never checked it out, I was surprised it ran as well as it did for a little while, on about 7-1/4 cylinders
I am about 99% sure I am just going to swap in a new GM long block, 5.7 TBI engine. That will be the most economical, time and $$$, way to get this thing back up and running. All the rest of the powertrain has been rebuilt/new, might as well not leave the engine out of the mix
My reasons for sticking with the TBI 5.7:
1) I have a freshly rebuilt 700R4. If I had a 4L60E, I would consider a newer/more powerful GM engine. But, I don't want to use/have to reconfigure all that TV cable stuff again. Sure it could be done, but I think my 700R4 will last longer with sub 300HP going through it
2) I can get a complete GM long block, oil pan to valve covers, for around $1,700 delivered. Time wise, just swap on my intake and exhaust, stab it in, done.
3) My throttle body, injectors, and all of the sensors for the TBI system are brand new. New wiring harness, too.
4) In the past 3,000 miles, I have installed the following new parts on this engine: starter, water pump, ps pump, all heater/radiator hoses, idler tension bearing, AC delete pulley assembly, distributor.
5) I already have motor mounts welded in place for this engine, and I will be able to reuse all of my exhaust.
6) With a "not healthy" TBI 350, the power was good. I am sure a healthy one will feel even stronger. When this motor was running good, 16-17 mpg on the highway was normal.
7) Even though my axles are "modified" (Warn Full Float in the rear/Detroit Locker/welded tubes) (chromo 44 shafts in the front/Tru-Trac/internal mount hubs), they are still an AMC 20/Dana 30. I don't want to be playing with fire. If you know me, I drive my vehicles hard. I don't abuse them, but if I have 300+ HP, I will use it
That's the way I am leaning now, just swap in another TBI 5.7 long block and call it a day
