NV3500, NV3550, or NV4500 Questions...
Polarfire
Jeep Aficionado
Columbia
MO
As some of you know I'm in the middle of my Scrambler rebuild and I'm at a point where I'm researching upgrading to a stronger transmission. The drive train that came in my Scrambler when I acquired it was a LT1 350 attached to the stock T5 transmission and Dana 300 transfer-case. It was performing just fine on the street but I never abused it or took it offroad prior to tearing it down. I know the T5 is weak behind a V8 and I'd rather just upgrade now if it is within a reasonable budget. The requirements I would like are to keep it a manual, have an overdrive to be able to cruise at 70-75mph with no problem, and keep cost (including any rebuild and adapters) as reasonable as possible. As with most folks on here I can't just open up my wallet and buy anything I want. I've kind of narrowed it down to the NV3500/3550/4500 transmissions but that doesn't mean I'm not open to other ideas (I have a T176 but it doesn't have an overdrive and it needs rebuilt). So, what are the pro's and con's to the previously mentioned transmissions and any opinions on which would be the best way to go? Btw, my LT1 350 I believe is pretty much stock and not pushing high horsepower.
Thanks for any info!
How about the ax15? It is arguably as strong as the nv3500 and Novak carries everything For the swap and have a great know ledge page about it. I bought one for $175 and am putting it in my scrambler this year. From what I hear the ax15 is cheeper to fix as well and more of them are floating around since they were in Cherokees and grands as well and behind v8s from the factory.
Welcome to the club of lt1s.I thought I was the only one left with the only dinosaur.. I'm sure your not talking about the new 6.2 lt1.... I myself have had my lt1 in my 7 from 96. My camaro has one as well.. There great engines but get use to changing opti spark distributors and always have one one hand with all the tools to change it.. I could do one in about 20 minutes now.lol. what year is your lt1? I run the 4l60e trans and the camaro is a t56 . but from factory stock they came with t5 transmission on base model. Z28 and as had the 6 speed upgrade. . but for the nv3500 your going to need a adapter spacer. Same goes for the ax15. Sorry can't help much on the manual as I want auto. I would stay with the t5 as its already there .
I'm not opposed to an ax15 but I wasn't sure if it was up to a V8 with some offroad "abuse".
I swapped a NV3550 into a CJ7 a while back.
Awesome tranny, holds up to abuse, but some notching was needed to get it to fit in the tranny tunnel.
I had to adapt 2 tranny tunnel covers to make one to cover it all up... it was behind a 6 though, not an 8 and we ran the D300 off the back of it.
If you look closely, I had to move the rectangular opening as well and stich in a strip at the top, so it is funny custom.
We then had to end the shifter a bit to clear the center console... it all fits if you "massage" it.
A couple more things, sorry, I keep forgetting them and remembering others.
Inspection plate from the T5 won't work, you need the AX-15 style as the bellhousing is different.
And I found a finished shot.
It was the 2nd and 4th and/or reverse that was too low and hit the center console.
You also need a pigtail plug to do the reverse lights that the kit didn't come with and the mount from the NV3550 to the tranny skid plate was also a b**** to find.
The plate is the black one sandwiched under the NV3550 and the torque arm
I installed a 4500 behind my LM7. I would rather spend the extra money to have a trans that is overkill than have one that is just ok for what you have at the moment. I know one day, the Scrambler will have more power. :)
I have 4500s in a 1989 XJ with Chevy 350 and 5" lift / 33"s and in a 1968 M715 (military truck) with a 1st Gen Cummins 6BT pushing 40" MTRs. I'll admit I have never invested in the actual cost of one of these transmissions, as these both came as mostly finished projects from other people and were deeply sunken costs, but if you can get into one at the right price I can't imagine a better tranny 5-spd / OD. I have had the XJ 11 years and I have beat the crap out of it towing and doing things I shouldnt and it has never skipped a beat. And in the M715, well, its almost a requirement.
Also you asked about cons...con is weight, and cost. size too...but they fit into a CJ fairly well. In the XJ...the tunnel is banged out and the gas pedal moved to the left about 1.5"
With a LT1, go NV4500. I have a new AX15 behind a maybe 200hp 6, with your torque and HP, go big :twocents:
You don't save any money replacing/rebuilding transmissions, plus future down time sucks, or being stranded somewhere. Can't really fix a transmission on the side of the road/trail :twocents:
I have a nv4500 behind a cummins in my scram and if you get the 5th gear fix in a new or rebuilt trans that should be the last trans you ever buy for it. Its got to weigh 250 -350 lbs with the flywheel. Without a body lift I have it and the dana 300 tucked higher than a stock cj.
Thanks for all the replies. What donor vehicles should I be looking for the 4500? Obviously a 4500 would be the best but if I find a good deal on a 3550 I assume it would be ok too. What kind of prices are we talking about here? What would a good deal price-wise be?
Thanks for the info! What is the "5th gear fix"?
In factory form the 5th gear would back off its main shaft because over time the retaing nut would unthread itself. The fix is to pin or lock the nut to the shaft so it wont back off. when rebuilding its not an issue to preform this fix. I think you can even do it on the truck if you can acess the top of the trans. I wanted to not have to work on my jeep after I finished it so I got a fresh rebuilt trans and I DID NOT have a core trans to turn in so with a 3 year warranty I paid 2100 bucks for the trans with a cummins bellhousing and a clocking ring shipped 800 miles. I choose to buy it on ebay from a longstanding seller with A lot of excellent feedback. They can be had for 500-800 bucks used but I didn't want to go that route.
The shifter tower sticks up through the insection plate for maximum clearance. With a body lift you may be able to get it high enough in the rails to tummy tuck it
I paid $1400 for mine. Bought the adapter kit from Advance Adapters to bolt up the Dana 300. Drilled the adapter housing so I could clock the 300 as flat as I could get it. Kit consists of a new output shaft, 5th gear fix, and tail housing. I installed it myself, easy to do if you have the right tools. (I bought them off www.4x4tools.com)
Mine is the MT8 with the 6.34 1st gear out of 92-94 GM trucks.
You can find them in later model trucks with Vortec LS V8s in them. Makes it easier to find bellhousings and other misc parts if youre doing an LS swap. I got a lot of parts from Rock Auto.
These are the clutch parts I used. I went cheap on the clutch because I wasnt sure if everything would fit. It was all trial and error at the time. However, all my parts are still working fine.
Clutch Parts
-Throwout Bearing 1962 Chev Bel Air 3.8L I6 NATIONAL P/N 1697C (ROCKAUTO)
-flywheel SACHS P/N NFW1050
-clutch kit P/N 04-232
-flywheel bolts ARP P/N 134-2201
-pressure plate bolts ARP P/N 134-2201
-pilot bearing GM P/N 12557583
If I was to do it again, I would have bought the clutch kit from Advance Adapters when I bought their bellhousing.
here is some useful info.
http://en.wikipedia.org/wiki/New_Venture_Gear_4500_transmission
https://www.novak-adapt.com/knowledge/nv4500.htm
http://www.advanceadapters.com/categories/nv4500-retrofit-adapter-packages/79/
http://www.4x4tools.com/nv4500tools.html
I found an NV4500 from a '95 Chevy 4x2. Does it have to be a 4x4 trans or can a 4x2 work? I've also found an NV3550 from an S10 which I think would probably be plenty strong for my setup.
It will work but your going to need to tear it down to swap outputshaft and source you a tcase adapter to go inplace of the 2wd tailshaft. UNLESS you have enough room and run a divorced tcase but your looking at putting it in a scrambler right?
