Just another typical day at the shop. .
It should get interesting on the dyno with this one. This 572ci engine with boost should make some power. :)
After it's all installed and broke in, it would be nice to have a you tube vid of her lighting up the tires. See how long the car can do a straight line.:smokin:
The next project at the shop. It will be getting a 6.0l/4L80E/Atlas swap.
More than likely all new parts on this build. It may get the new generation 6.2l instead of the 6.0l.
How much HP did that twin turbo v8 put down? Wow!!!!!
It's about 850hp at 9 psi boost spinning the tires running E85. That stuff is the devil's nectar. Lol
I did get the engine running in the 1968 Charger finally. The distributor will eventually get modified into a much smaller housing with a billet cap but you get the idea. The LSx coils are mounted under the engine and the harness is hidden so very little wiring and such is visible. I think the new personalized tag should read HLCATKLR
<iframe width="560" height="315" src="https://www.youtube.com/embed/mqiDfzOuTH0" frameborder="0" allowfullscreen></iframe>
