Intermittent Vibration Problem
MomoJeep
Seattle
WA
OK, so I'm trying to track down this annoying weird vibration problem. here's the deal:
-The original T5 transmission suddenly seized up on the freeway one day. I figured this must have been the problem. Replaced it with an AX-15 conversion. But the vibration still happens.
-It comes and goes. It usually happens when I drive over a bump, then goes away. It doesn't seem to matter if I'm in gear or not.
-It's a fast vibration like driving over a washboard. It rumbles and I can feel it in my seat. I do NOT feel it in the steering wheel/pedals/front end.
-Replaced the yoke/output shaft from the Dana300 because a U-joint bearing cap was spinning a bit.
-Had rear driveline rebuilt and balanced, new U-joints.
-Got brand new wheels and tires, still vibrates.
-Still vibrates occasionally for short periods of time, then goes away, usually when I change speed.
-I noticed about .015" of play between the Ujoint retention tabs in the read diff yoke. Could this be the problem, or part of it? (I did replace the Ujoint mount straps with new ones).
-I noticed the front output shaft from the Dana300 has some play, and the front driveline is not straight (I can see it wobbling when in 4wd with the hubs disengaged). Could this be turning a bit when I'm driving even in 2wd causing a vibration? I used plastic twist ties to hold it still to see if the vibe goes still happens when I know the front driveline is not turning.
-I noticed my front wheel bearings have a little play.
- One of my engine mounts is not aligned well, and the rubber block is tweaked pretty good to make up for the misalignment, but seems to hold well.
Any thoughts?
Any thoughts?
I'll take a stab at it.....rear wheel bearing going bad.
Since it happens when you change speed, I will bet on the rear yoke tabs and that extra space. I had a wrangler in college where one of the spring clips came loose, the bearing cap slipped out a little and that is how it acted.
You could try a shim to see if the joint is shifting between the tabs....
I think you may be right. I found that the front wheel bearing were a bit lose. The rear did not feel lose, which is what I expected. Do you think they could still be the issue if there is no play, no oil leaking, etc, in the rear?
Even thought the vibration *seems* to be coming from the rear, I decide to first tighten up the front wheel bearings. I will test drive it now to see if the vibration is still there.
No, not when I change speed. It happens usually when I go over a bump! (Weird, huh?). Other times it happens on it's own. When it happens, I can take it in and out of gear and it doesn't effect the vibration. This makes me think it's not in the driveline/yoke areas. Also, if I put on the brakes or coast to a slower speed, it doesn't always go away immediately, but usually does by the time I get under 25mph or so...
